Question about Acer Aspire 3610 Notebook
Cd/dvd drive doesnt seem to be working green led light doesnt com on when dvd is put in and cannot open the cd/dvd door but have used manual release to get dvd out
  • 106 Answers
Your cd rom is brike you need to buy a new one
Posted on Nov 27, 2007
DVD disc door won't open.
have you tried going to my computer right clicking on the drive and pick eject from the menu? if this doesnt open there is an emergency lock release on the from it is a very small hole in the face of the deck use a small paper clip or stiff piece of wire and insert it into the hole and push lightly this will release the door for you
Aug 29, 2010 | Lite On LITEON 8X DVDRW +/- Burner
CD/DVD TS-L632m ATA Device Doesn't read CD or DVD
Step 1: Unplug the power code from the Drive and start you PC and let it boot to windows without the drive.
Once Windows is up and running.
Step 2: Shutdown the PC
Step 3: Connect the power code again to the drive and then run you PC.
This should fix your problem
Mar 08, 2010 | Computers & Internet
The door is stuck. I push the button, the green light flashes, but the door won't open. Dell Latitude/Inspiron CD-RW/DVD Combo Drive :8W007-A01
It is most likely jammed. If you look on the front of the drive, there should be a little hole. Use a paper clip that you have straightened out and insert it into the hole. When you feel resistance, push it hard carefully. The hole is an emergency/manual tray release. It should pop the tray out. If you can't get the tray to release and you have a CD or DVD in the drive, you will have to take the drive out of the system and take it apart to get the platter out. Of course this means you will have to buy a new drive as the old one will probably be unusable, even if you try to put it back together.
Feb 11, 2010 | Dell (8W007-A01) for Latitude, Inspiron...
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Craftman door opener brand new wont work?
Sounds like the drive gear is stripped. Remove the cover and take a look. It is white nylon and is just in front of the motor.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cd/ dvd drive on dell inspiron 6400 does not work
Possibly there is some dust particles on your dvd drive's lense. If that's not the case it is defective.
Dec 18, 2008 | Dell Inspiron 6400 Notebook
Cd drive
1.If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
2.Double-click My Computer .
3.Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
4.If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
5.If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
6.Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
7. If the door still does not open, do the following:
1.Close all programs and shut down the PC.
2.Unplug the power cord from the power outlet.
3.Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
NOTE: On some models the release hole and the drive activity LED look similar and are about the same size. Do not force the paperclip into the hole if it does not go in. Make sure that the hole is not actually the LED.
Figure 1: Possible location of manual release hole
Picture showing possible location of manual release hole
4.Straighten the paperclip and insert it into the manual release hole until resistance is felt.
5.Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
6.Remove the paper clip and gently pull out the drawer until the disc is accessible.
7.Remove the CD and turn on the PC.
8.If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any edge of the computer's interior metal.
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface (like the metal frame of the PC).
1.Turn off the PC.
2.Unplug all power cords from the back of the PC.
3.Press and release the Power button on the front of the computer.
4.Remove the side panel.
5.locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
6.Unplug the power cable and wait five seconds.
7. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
8.Replace the side panel and plug in the power cord.
9.Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Oct 25, 2008 | HP Pavilion a1330n (EL466AA) PC Desktop
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
May 30, 2007 | LaCie (300987U) DVD RW Dual Layer Burner
Acer Aspire 3610 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
