Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker works but
We are getting a lot of white stuff in the glass after the Ice melts.
  • 410 Answers
The white stuff is hard water minerals that are in your water. they get concentrated when water freezes. try a good quality water filter.
Posted on Dec 19, 2007
White sed iment from ice cubes
This is limescale as you must live in a hard water area, and I expect you also get scale in your kettle. You need to descale the ice-maker if you have one, or if it is from a mains water tap, you can use a under-sink filter, a Brita Jug, or buy bottled water to make ice. The calcium is actually fairly good for you.
Aug 29, 2017 | Dishwashers
Replacement ice maker dispenses ice that has cloudy residue as ice melts
This is a physics issue due to the minerals that are present in your water. When the water is let into the ice maker, the minerals are dissolved in the solution, when the water freezes the molecules are brought closer together and the minerals are squeezed out. When the ice melts the minerals drop down to the bottom of the glass because they are cold and out of solution. The process is called precipitation of solids. The common mineral are lime, calcium, fluoride and many other organic substances. It wont hurt you it just looks bad.
Aug 27, 2015 | Refrigerators
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Sediment at the bottom of my glass of ice water
The sediment is condensed minerals. Applying a filter should fix that problem.
Aug 31, 2009 | Refrigerators
Ice maker
Check supply tube to see if frozen or blocked using Q-tip or feel to see if frozen. if Frozen, hold up clear glass with heated water placing tube in hot water. Hold till ice in tube melts. Clear glass will allow you see ice slip out.
Jan 19, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
116 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
