Question about Bodum Antigua 5670/5671 Electric Burr Grinder
Bean Bowl Sheared off
Hi, We were carrying the Grinder back from a party and the bean bowl sheared off the base - the base is perfect and the bean bowl cannot be attached to the base.. any where to buy the bowl?
  • Anonymous May 16, 2008
    The bean bowl broke at he base and will not stay attached. I found the part, is it easy to replace?
  • ekcat65 Dec 07, 2008
    My daugther accidently knocked my grinder off the kitchen counter and the bean bowl broke and won't lock on. I haven't been able to locate a replacement. Can anyone help?
No applicance web site sells this model's replacement parts. Go direct:
www.bodum.com
Posted on May 20, 2010
  • 833 Answers
Try www.smallappliance.com They've got all kinds of stuff. If the online doesn't have it, call them. Other suppliers? Here's a bigger list: http://www.jneuhaus.com/appliance/index.htm
Posted on Dec 03, 2007
Which one is better a coffee bean or ground coffee?
if coffee is prepared with fresh grinder bean then it gives ultimate taste to coofee with perfect aroma. Some top-range bean to cup models have integrated bean grinders to do this for you, or you can buy a separate grinder. If you grind beans yourself, you'll need to choose the extra-fine setting for espresso brewing and make sure you thoroughly clean and maintain your filters, to prevent them getting blocked. Get Complete info about the best coffee best coffee grinder here.
Sep 04, 2014 | Nesco Cr-1010-prr Coffee Bean Roaster, 800...
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Overloaded grinder no longer turns after puff of smoke!
the shear pin, which goes through the grinder blade base and the motor shaft has 'sheared' off the protect the motor from overload. The metal bits of the pin need to be removed from both the grinder part and the shaft, a new one inserted. It is a 'pressed fit', so it will be hard to remove.
After the bits are removed, a common 'roll pin' of the proper diameter should be a suitable replacement
Feb 04, 2010 | DeLonghi DCG39 Electric Blades Grinder
I cleaned my Breville grinder and tried to put it back together but the bean container will not fit back in. Please help.
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
Dec 13, 2008 | Breville Conical Burr Coffee Grinder -...
The bean container won't fit into the machine
I had this problem and fixed it. At the bottom of the bean container is a tab that extends about a quarter of the way around. This tab is designed to fit into the base inside a quarter-circle groove that rotates back and forth slightly when the bean container is installed or removed. In my case, the groove on the base was not aligned correctly, so I inserted a blade screwdriver into the groove and rotated it gently in a counter-clockwise direction until it stopped. After this, I could install the bean container as expected.
Nov 23, 2008 | Jura Capresso 560 Electric Burr Grinder
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Water in bean dispenser/grinder
If you look at the bean hopper you will see two screw, loosen this and take off the bean hopper. Now you will see the grinder, you have to take of the adjustment on the side, that plastic on the grinder.
Now you can turn the ring anticlockwise, and take out the middle of the grinder.
Let me know if you wondering about anything
Jul 13, 2008 | Saeco Magic De Luxe Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Bodum Antigua 5670/5671 Electric Burr Grinder Logo
410 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
