Question about Zanussi FLA1001W Front Load Washer
Rinse cycle imbalance
The problem only occurs on some programs. When OK the action of distributing the wash load seems to be a few turns left, then right and then left again. The speed then gradually increases and the evenly distributed load spins OK. However on some programs it seems to skip the distibution sequence and tries a faster rotation causing the unbalanced load to really throw the drum about. I have replaced the shock absorbers thinking it was this, but they were OK anyway. Can you please suggest any causes of this behaviour?
    President:
  • 1,294 Answers
Suggestion: See that the machine is balanced properly on its legs. The front legs should should be screwed up (and locked with check nut) maximum; but for some adjustment if floor is not proper. Screwed up means minimum gap between machine & floor.
Next see if any springs have come loose inside washer (plug off the wall first) Next, it is good to weigh your dry laundry to see if you are using the correct weight according to the manual.
Posted on Nov 28, 2007
  • prem mathew Nov 28, 2007
    And dont forget to rate me, it helps, to know if i am helpful....
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
My whirlpool front loading washing machine keeps stopping before the rinse cycle. I've cleaned the filter and the drain hose as well as all the inlet hoses. It stops and all the lights flash and it wont...
While it stops to rinse , does it drain off? if not there is block on the drain valve and so there is an error on the board because the water level sensor has to switch OFF and then ON to confirm that water has come in for rinsing.
So if the cycle is absent the possible fault can be the program controller. So you need to check the actions when the fault occurs, check for drain,.then after drain the inlet valve must open to allow water and then the water flow must cut off to start the motor.
If there is no action and output then the controller can be defective.
Apr 12, 2011 | Whirlpool Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Will fill but not wash or spin
Does the motor run?  Does the water get pumped out at the end of wash cycle or during the rinse cycle or when you turn the dial by hand to the end of a cycle?  If the water gets pumped out then the motor is OK but the clutch is not working.  If the motor is not running then that is the problem.  If the water fills and then nothing happens (the dial does not turn by itself) the timer is bad.  If the timer is bad but you turn it by hand the other actions (wash, rinse, etc. should work indicating no problems with motor and clutch).
May 30, 2009 | GE WBSR3140DW Top Load Washer
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Not washing
helen going by what you are saying i would say its the program cycle switch needs replacing,adrian
Jan 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Zanussi FLA1001W Front Load Washer Logo
70 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
