Question about Rio DVR4100 DVD Player/VCR
Problem with programmed recordings
I have been having trouble with programmed recordings. Lately, I have set tv shows to record and when I go to play them back, there is nothing but snow. In addition, there is a flashing key symbol on the display panel at the front of the player.
DID you set the channel on the VCR to the sttating your recording? Also does your cable go to the tv, then to the vcr? If so the channel you record will be the one your watching. Or did you accidently screw the cable into the "cable out" on the dvr?
Posted on Feb 29, 2008
How do I record a programme on my new Sony smart tv
i am trying to figure out what you are asking, you asking how to record a program on your smart tv, but i sony dvd & blu-ray play.
the sony dvd & blu-ray player can only play recorder material.
the smart tv assume has streaming video rite, you would need a program like dish, cox, other types of providers, dvr, this device needs program, that can store the movies or shows, hard drive or storage device, i guess i need more information, if you are wounder how to get inter net you would need a provider and than you have streaming video, recording device that can store the information you want to watch later we call a DVR. in order to get to the setting for on line or internet you have to go into setting and look for internet options or under streaming, online configuration,
need additional information, equipment,
www.sony.com/smart_tv_programming_online
you could look at some videos on how to set up smart tv programming by going to
www.youtube.com/smart_tv_programming
" " / smart_tv_setup
" " / how to program smart tv
Mar 30, 2015 | Sony Televison & Video
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have an LG HR598D Blu ray hdd recorder but am having trouble working out how to program it to record tv shows.
Hit the menu button then go to timer recordings (I think. one menu item is for recording and one is for playing). hit new and enter the stations and times etc. To play back just go to
Another way is to do it through the tv guide but dont bother if the show runs early or late you will miss it.
Another is the one touch recording but it maxes out at 2 hours so not for movies.
One final caution - watch the time. i set it ot manual not auto as it stuffs up daylight saving in Aus.
Have fun!
Nov 24, 2010 | LG Televison & Video
When I record to dvd I can't plan on any other DVD player - can play on the toshiba dvr but nothing else?
Have you closed the recording? If the recording is not closed out, you will have trouble playing the DVD in other players.
It could also be that your DVD player you are trying to play on is too old or not designed to use burned DVDs. I also have trouble playing some burned DVD's in older DVD players, it has to do with how the recording is done, and there is nothing you can do about it. For example, I have a Sony 5 disc changer that came with a surround sound set up... nice DVD player, but will NOT handle DVDs burned on stand alone DVD burners or burned from a PC. It reads the DVD, and displays on the front of the player that it is not a DVD, and shows nothing on the TV.
Jan 01, 2010 | Sling Media The Slingbox Pro
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Can't get to recorded programs
Check and make sure you have the DVD Recorder hooked up to the TV. I think you have the Cable box or Satellite hooked up or else you could not record. So there is a second set of outputs on the back of your DVD Recorder, Buy a set of RCA jacks and plug them into the Yellow,White, Red Plugs of your DVD Recorder, Then plug the other end into your TV in either L1 or L2 inputs, whichever ones are free.
May 12, 2009 | Panasonic DMR-E85H DVD Recorder
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
Record tv
The VCR will have to be on channel 60 as well in order to record a program. Hope this helps....accordianman
Apr 25, 2008 | Quasar VHQ400 VHS VCR
Rio DVR4100 DVD Player/VCR Logo
53 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
Jaime Hernandez
JOHN TOPLISS
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
