Question about R.A.M. Computers LASCO-5540 Ceramic Radiator Heater
Heater model 5500
It worked fine last year. I plugged it in today and it will not come on. Won't show power to it either.
  • Anonymous Dec 16, 2008
    From the showroom, it worked fine. I moved the location and when I hit the on switch, nothing/ No indication of power. Ac at wall ok. Never did come on. Had to return it.
  • 1,420 Answers
You are sure you have power at the plug? If so it sounds like the internal circuit breaker tripped or the switch is bad. Either way, throw the heater away, they are not designed to be field repaired, sorry.
Posted on Nov 28, 2007
I have a Garrison electric portable heater which shows a code FF. What does code FF mean? Thanks in advance.
You might want to check with Garrison, there was a recall on some models last year. It might be worth your time.
Jan 27, 2015 | Heating & Cooling
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
2003 ford taurus heater fan worked fine last night but won't come on at all today.
I do not understand why people will continue to operate a vehicle when they know there is an obvious problem. They ignore check engine lights until the engine stops running altogether and then are "surprised" when they get stranded in the middle of the expressway in rush hour traffic. Then they blame it on the car!!!
In your case, you have ignored the warning signs of your blower motor failing ("making noise for a couple months"?) and now you are dumfounded as to why your blower motor now does not work at all.....I don't get it....!???
REPLACE YOUR BLOWER MOTOR!
Dec 26, 2011 | 2003 Ford Taurus
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Well my 5500 amp has evidently stoppe functioning.
What I would do is look around inside and see if anything is burnt or broken, pay close attention to the heat sink area.
With neither channel working you have something that's common to both channels that is causing the trouble.
You should be able to see any fuse by looking inside, they might be covered up, but should be easy to get to.
Nov 25, 2009 | Adcom GFA-5500 2-Channel Amplifier
I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Apr 16, 2009 | Hammering
Lakewood 5500 Oil Filled Electric Radiator Heater
same problem. good for one winter. stop working the next though the light is on...
Oct 30, 2007 | Lakewood (5500) Oil Filled Radiator Heater
R.A.M. Computers LASCO-5540 Ceramic Radiator Heater Logo
Top R.A.M. Computers Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a R.A.M. Computers Heating and Cooling Expert? Answer questions, earn points and help others
