Question about Philips DVD640 DVD Player
PHILIPS DVD 640/021
It plays very few DVD’S, and this happen after numerous “INSERT” and “EJECT” commands. Usually after some time I get the message “NO DISK”
It plays a significant larger number of VCD’S inserted. Maybe the 30% of them. Same amount of MUSIC CD’S.
All DVD’S and VCD’S are in good shape and able to play in a cheap Chinese DVD player.
Lens cleaning done with no success.
Thank you.
Andreas.
SOURCE: Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Posted on Feb 10, 2009
  • 814 Answers
SOURCE: Philips DVP 5992 DVD player disk tray opens without a disk
You can call Phillips customer support at this telephone number 1-888-744-5477. Tell them while using the disc player the unit failed to eject the disc and ask the for a way to solve the problem. It is best to talk to them in this case as the solution will involve a opening of the unit to figure out what has malfunctioned to cause this problem. I hope this information helps you with your problem.
Posted on Jun 02, 2009
  • 1348 Answers
SOURCE: my dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Posted on Jul 03, 2009
vortash
  • 431 Answers
SOURCE: The problem is i cant play mp3 or DVD s in my
Hi I am vortash I think you may just need a cd CD cleaner to cure your problem , most people overlook that DVD's need to be cleaned now and again as dust collects on the laser lens and sometimes just need cleaning ,
Get yourself a cd disk cleaner one that has both a fabric felt side for polishing the lens and a brush side for cleaning it ... Regards Vortash
Posted on Jul 21, 2009
projdoc
  • 2237 Answers
SOURCE: my phillips 5.1 dvd player not playing dvd disc, only playing vcd
the laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
Posted on Jul 30, 2009
My panasonic dmr-ez475v has a dvd stock inside and will not open or eject the cd. what to do?
I had the same problem. It would not release the DVD because it was not ready. What worked for me, was to insert a VHS Movie and play it for a few seconds, than stop it using the remote, then Eject with the remote, and then after removing the Tape, I pressed the Open/DVD button on the unit and now it worked, it released the DVD
Jul 31, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
CAnt eject DVD disc. Get message ''blocked'' Machine will play the DVD but when I try to eject nothing happens other than the message. What size lump hammer should I use?
if you want to just get the disc out there should be a tiny hole on the front of the drive where you can insert a paper clip firmly to eject the drive.
I would also check the rubber band / cogs by taking a look inside and see if there are any issues.
Also if you reboot do you get the same problem ?
Apr 13, 2009 | Televison & Video
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
Philips DVDR615/69
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
All of a sudden, dvd's won't play on my Mitsubishi DD 6040. After a very long time waiting on blue screen, I get a message that says: Please eject the disc, etc. This has just happened with a dvd that...
you can go to wal-mart or any electronic store and get a laser eye cleaner for DVD - I recommend the Philips system, for under $15 you get the DVD laser eye cleaner and a disk cleaner with a micro fiber cloth it's a great deal just DO NOT use it in a laptop, laptop's take a different type but the disk cleaner is universal
try this first
Apr 05, 2008 | Televison & Video
Philips HTS 6500 not reading my DVD's
I bought this item in Nov. of '07 and it worked great...for about 3 months then the dreaded no disc message appeared and has ruined my life. Howvever after not using this DVD player for a month or so i had decided to tinker with it to try and get it to work and it appears i have found a solution that is working for me so far. After being fed up with Philips and trying their "solutions" because as we all know the U.S. sells DVD's with the wrong region code (ha funny Philips people) i began trying to make this stupid peice of garbage work in any way. What i came up with is this: 1.) insert your DVD and wait to see what happens. When you get the no disc readings this is what you do. 2) Eject the dvd but do not touch it 3). While the dvd is sitting in the slot press and hold down the play button on the remote control and continue to hold it down 4) it may take awhile but give it a chance, and hopefully the DVD will "resume play" and start anew. If holding the play button down does nothing then try holding it and releasing it in intervals until something happens. If nothing ever happens then i guess you SOL. I know this is not an desired fix to the problem but so far it has worked for me. I noticed this because the stupid thing will would read a cd and this got me thinking. This way is kind of a jump start to get the dvd going....hope this helps someone
Feb 20, 2008 | Philips HTS-6500/37 System
Philips DVD640 DVD Player Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
