Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Belkin adapter F5D7051
My Belikn adapter is not recognized by my laptop any more. It worked fine for a wek and suddenly stopped. Re-instalation does not help. The USB port is shown as "unused" even if the adaper is in it.
  • 3 Answers
I would think its the usb slot your using maybe its shot. if you use the extender thing you could try not using it and reinstalling. when reinstalled just plug the usb directly into it.
Posted on Dec 24, 2007
My NV55c laptop usb ports on the right side suddenly have stopped working.
Motherboard issue.assuming all the drivers are properly installed. Not uncommon. Use the remainder and if necessary get an adapter to increase the number of ports you have.
Aug 21, 2016 | Gateway Computers & Internet
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
Usb device not recognized, works only when plugged on hub
All PCs provides power supply via USB port. The power is controlled by electronic circuit. Sometimes when overloaded the circuit burns out (the last controlling transistor, actually). This does not prevent the data communication, because it is separated circuit. But if the device is not powered it cannot communicate. When you plug the USB device to powered USB hub, then all go right.
Are you able to use the USB ports with other USB-powered devices like USB sticks, mouses, cameras? If not, the mentioned circuit is burned out. If they work OK, then your internal USB hub provides less power current than needed. In both cases there is nothing to do. The circuit resides on the mainboard of the laptop and replacement is expencive. Use it with that external USB hub you have.
Apr 08, 2012 | ASUS G73JH-RBBX05 Refurbished Notebook PC...
My Maxtor One Touch III external hard disk has suddenly stopped getting recognized on my laptop. I am using a Windows XP, SP 2 OS. The system is unable to recognize the USB device. Can someone please help?
Check power of HDD, that problem can usually manifest because some of your usb ports can't send enough Volts to your device, restart your machine, check connections, and it should work again as charm :)))
Please rate my solution, thank you :)
Apr 13, 2011 | Maxtor OneTouch III (T01H300) Hard Drive
My laptop running XP home edition does not recognize my WUSB100 is connected.
Dear ctbryantiii,
What do you mean "not recognize" ? there is any error message pop up?
need to know for next step.
regards,
dm
Feb 15, 2010 | Linksys WUSB100 Wireless Adapter
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
I am trying to install a wireless usb adapter. Problem installing driver software "process cannot access the file because it is being used by another process2 please help
Did you have a similar wireless adapter install previous to this one? If the software is similar then you need to uninstall the old software so that you can install the new software. The problem might be the old software version is running and you can't write over a file that is running. You can't delete or overwrite it until that process is closed.
Oct 01, 2009 | Belkin (F5D7230-4) Router (587009)
My front usb ports on my computer suddenly stopped working. I do have vista, and I swear the problem arose after an update. I can plug my ipod into them, and it charges my ipod, but it does not open...
Go to Start-Programs-Accessories-System Tools-System Restore and back your computer's date to some time before you installed this update. You will then know if the update actually caused the problem.
Sep 21, 2009 | E-Machines eMachines Desktop PC
Wireless adapter has suddenly stopped working.
First unplug your adapter and boot your computer. It wouldn;t hurt to reboot it once as well. This should clear out any settings. When it has fully booted up only then insert the adapter into a different usb port. If it recognizes it and works it can indicate a usb problem.
If it finds it but doesn't connect a adapter problem. You can uninstall it and reinstall the drivers and it might work. If not replace. If it does nothing then its died on you and your adapter needs to be replaced.
Most adapters and home network units (wifi routers etc) only last for 1-2 years before they act up or die on you. Very annoying and can be expensive. I have a stack of wifi routers where the wifi isn;t reliable but the rest works. And a drawer full of various wifi adapter that are detected but not connected and a few just plain dead ones. All of them seem to fail at about the same time after purchase.
Jul 09, 2009 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
133 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
