Question about Bang and Olufsen Beosound 2000 Shelf System
B&o sound system not working
Have a b&o 3000 sound system and the cd player not reading the cd and also not spinning or will spin for 5 seconds and the door opens and displays asks me to load cd any advice please
  • TellMeMore Feb 09, 2008
    I have the same exact problem and took it to my local B&O repairman. The store employees told me where to go, instead of giving it to them-otherwise, the repair cost would have tripled. It is where they send their repairs!
    If you live in the Orange County area of So Cal, I have the name of the repairman. Glad to give it to you: 949-722-6897. Owner/Repairman is "Dimitri". This is the ONLY place I would take my system.
    He said that the laser is not "reading" the cd. Repair cost <$100.00
  • patrick_defr
    patrick_defr Nov 15, 2012
    Hi had the same problem,it was due to smoke of the open fire that had made the lens dirty. I cleaned the cd lens with a cue tip and some alcohol and now it works perfect again. Suppose that when the laser gets no perfect feed it blocks the CD player and it doesn't spin.
    New Friend:
Cleaned the cd lens with a cue tip and some alcohol and now it works fine again. When dirt settles on the lens it blocks the CD player as the laser doesn't get a correct read
Posted on Nov 15, 2012
Try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
Posted on Jan 24, 2008
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Cd will spin for about 5 seconds and stop
The drive has failed. It can't read the disc.
Nov 20, 2014 | Audio Players & Recorders
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
I have a wave machine aprox 15 yrs old.If I manually spin the cd once or twice it will read and play but begins skipping on later tracks.Also volume control is sometimes problematic.Seems like it needs an...
Clean lense on cd pickup. Remove spin motor. Spray some WD40 in the bottom of the motor and connect 5 volts dc to motor and spin for a few seconds in both directions. The motor brushes need cleaned off. This works on most all cd players. Reinstall the motor.If this does not fix replace cd assy. Check solder connections on volume control. If ok replace control.I had one of these that i sold for $500.00 on Ebay. Even used there is a demand for this item.
Nov 20, 2009 | Bose Acoustic Wave (32022) 5-Disc CD...
I have just instaled my harman kardon ks200 and there appears to be a problem? i can hear the cd spinning louder when listerning to track 1 than i can when listerning to track 10 eg. should there be a...
* Tech Stuff *
Audio CDs do not spin at a constant rate. They are designed to be read (for music) at a "constant linear velocity" of about 1.25 meters per second. The data is written in a tight spiral starting at the inside of the CD. The CD spins the fastest when reading the inside tracks and slows down as it reads towards the outside edge. Imagine circles on the CD surface. The inside ones would be smaller than the outside ones, of course. So, if you are reading evenly-spaced bits on the lines of those circles, you would need to read fewer outside circles per second than the small inside circles.
* Basic Issue *
When the player is reading Track 1 the CD is spinning at about 500 rpm. During the last tracks of a (full) CD it only needs to spin at about 200 rpm. It doesn't work the other way around for compatibility reasons.
* More Info *
This is why you are experiencing the difference in mechanical noise at different tracks. It doesn't necessarily reflect a defect, but understandably, a consumer would prefer a quieter system, which does differ between manufacturers and models (I couldn't specs for a KS200 HK device) Yet, if the noise is substantial, it may very well be indicative of a problem, e.g. something stuck in the drive and being whipped around in a circle at high speed. I wouldn't say this is particularly likely.
* Possible Help *
What would normally mitigate this issue is not getting too close to the player while listening. Normally having the primary listening position several few feet away (across the room) would suffice to minimize noise heard from fans and spooling CDs.
May 14, 2008 | Televison & Video
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
CD Player
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Nov 14, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Disk error
can you hear the cd spin?
more times than not the laser is bad.
Oct 18, 2007 | Sony RDR-VX525 DVD Recorder/VCR
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
1,479 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
