Question about Canon PowerShot A620 Digital Camera
Dropped my camera from about 36" on a linoleum floor
I dropped my camera and it now only powers on when it is pointing down. It works completely fine but only if it is not pointing straight ahead. As soon as I tilt it up to point it straight ahead it powers off. If it is upside down pointing up or sideways, it WORKS. It stops working when it is pointed straight ahead or when i tap on it. Obviously something is loose. Is there a common part that I would look at?
  • Anonymous Apr 12, 2009
    Thanks Pesach - I had the same problem, and just bent the little spring tabs a little bit in each of the battery holes and everything works fine now.
    Welcome Back:
    Visited the website for 2 consecutive days.
I dropped mine from about five feet. I phoned Canon. They wanted me to send it to Illinois and estimated $105 for repair. Following leo2's suggestion I found Superior Camera in Woodland Hills in the Fixya Repair Directory. Zvi diagnosed it as a bad battery contact and fixed it at no cost. It sounds like your problem could be the same. The impact of those heavy batteries "loosens" the contacts.
Posted on Feb 15, 2008
    Master:
  • 619 Answers
Hi , let professional camera repairman fix you camera , fixya has recommended repair shop near you just enter you enter zip location number .
Posted on Jan 29, 2008
Power steering jumping off straight ahead position
Make sure the power steering fluid level is at the appropriate level.
Also, if you haven't changed the fluid according to the manual, it may be time. Let the mechanic know your observation before changing the fluid.
Apr 11, 2016 | Cars & Trucks
What is the correct positioning of head lamps for a dodge 3500 van 2000?
Headlights should point straight ahead, single sided headlights should drop 2 feet over 100 feet. Dual sided lights drop 1 foot in 100 feet.
Sep 12, 2014 | Cars & Trucks
How do i adjust my headlights on a 1998 buick century custom? their facing down instead of straight ahead
sounds as if they were installed improperly. take them out and replace with wires pointing downward.
If the whole assemble is pointing down it is probably an adjuster screw
that is detached from the casing.
Mar 11, 2013 | Cars & Trucks
Bleed power steering on 2008 dodge avenger
to bleed power steering, with front wheels off ground slightly with front wheels pointing straight ahead.engine off. remove power steering filler cap.add power steering until fluid level stop dropping,wait couple minutes and wait, add fluid until level stay at full cold mark on power steering cap dip stick. dont over fill.when fluid level stop dropping, start vechicle,let it idle few minutes. see if fluid level drop if so add more fluid full cold mark.then turn steering all the way to left and right with out hitting a stop.turn steering wheel several times, then turn front wheels pointing forward check power steering fluid level.if power steering fluid level stop dropping air should be out of system, if steering turning wheel dont turn smoothly and power steering fluid look light tan color air getting in the system.check all power steering lines to rack and power steering pump for leaks.be sure you replaced all the power steering lines with new o rings if not you will get a leak.if you find a leak, you need to fix the leak and bleed system again.dont drive vechicle if your steering dont feel right,have vechicle towed to a garage.
Aug 25, 2012 | 2008 Dodge Avenger
I have a samsung ES55 camera when i try to turn it on the lense pops out then straight back in and the camera turns off it will not turn on please can you help thank you
If you've recently dropped the camera this problem may be due to lens damage, with the camera shutting down to prevent further damage. If this is the case the camera will need professional repair.
If it hasn't been dropped this problem can usually be attributed to the camera's power supply. Make certain that your batteries are serviceable and fully charged - batteries more than one year old are candidates for replacement, especially if the camera sits idle for weeks at a time. Also check the battery and camera contacts for corrosion that can build up and prevent the required power flow between the batteries and camera. Even if you don't see any buildup, wipe the battery contacts and camera contacts firmly with a clean dry cloth. Heavy buildups may require cleaning with a fine wire brush, steel wool, or even sandpaper. After cleaning, be sure to remove any residue from the battery compartment before installing the batteries.
While the above steps will not cure ALL power problems, they are effective in a large percentage of cameras. I hope they work for you.
Nov 23, 2010 | Samsung Cameras
Vivitar 283 looks firing but image is dark. when i turn the dial from the yellow to blue it fires but the green light turns on and there is no beep. its weird when i postion the head bounced straight up...
Let's review how the Viv283 should operate, bearing in mind that it was designed for manual cameras.
  1. On the dial on the side, set the arrow to point at the ASA setting you (your camera) is using.
    Example: ASA 100 is one dot below the labeled 125 setting.
  2. Look at the four color segments, purple/blue/orange/yellow. Each is lined up (not necessarily exactly) with an f/stop. Each segment also highlights a maximum distance that can be used.
    Example: at ASA 100, the orange segment lines up with f/4 and allows a maximum range of 30 feet.
    (These maximum distances assume the flash is pointed straight ahead.)
  3. Choose the f/stop you want to use. Rotate the sensor on the front to that color.
    Example: on my unit, the sensor is marked "auto thyristor" and its orange setting actually looks red.
    There is also an "M" setting, for manual (full-power) operation.
  4. Take the picture. The flash head can be pointed wherever you want, straight-ahead up to 90 degrees (I usually used 45 degrees). The sensor will quench the flash as soon as it thinks enough light has bounced back from the scene.
    Example: at f/4, with a 45-degree flash angle and a light-colored ceiling, I could usually count on a bright-enough exposure out to some 15 feet or so.
    If there actually was enough light, the little green indicator on the back will glow briefly. If there wasn't enough light you won't get the green indicator and you should try again with a wider f/stop.
  5. Or...
    just set the sensor on the front to M for manual, and the flash will dump its full output. Then it's up to you (or your camera) to cope with that 120-guide-number output.
Hope that all helps.
Apr 07, 2009 | Vivitar 283 Flash
OverExposure Even in AUTO mode
usually it's the opening in the lens doing it. it may be stuck open and not closing down during bright sunshine. The only thing you can do is drop the exposure down. Canon offeres a repair for about $100 or a refurbished SD750 for the same money
Jun 06, 2008 | Canon PowerShot SD600 Digital Camera
Digimax 4010
Hey shiney_sapph,
I am assuming you need the driver for this camera for your new computer so I have provided a link below where you can download it from the manufacturer. Once you go to the link under the download center in the first drop down menu choose the s-series and then under the next drop down menu choose model #401 which is the same as your camera and then left click the go button. This will bring up another screen and at the top is a button to download the driver. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Samsung Digimax 4010 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
What the ?
I think theres nothing you can do.. professional fix is badly needed.
Dec 29, 2006 | Fuji FinePix S5000 Digital Camera
Canon PowerShot A620 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
