Question about Compaq Presario 5000 PC Desktop
Compaq keyboard i would like to know how to assign the very top row of buttons as a shortcut. or what is the purpose of that row of buttons. brianl36@dodo.com.au The top Row of Keys on the included keyboard have no pre-progammed functions. How can I assign fuctions to these buttons? Keys: Connect, Search, Email, Club Q, ?, Calculator
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Posted on Nov 27, 2007
Volume control
Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
Right click on a empty area on desktop, and click on New and Shortcut.
Paste the following in to the location of the item area:-
%windir%\System32\SndVol.exe -f 49825268
Click Next button and give a name to the Shortcut and click Finish.
Now You right click on it and select Properties.
Click Shortcut tab.
Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
Click OK/Apply
Is There Keyboard Shortcut For Volume Control
Mar 13, 2015 | Computers & Internet
How do i change my volume and where is the fn key in this keyboard
    Is it possible to control the master volume with some keyboard shortcut? I would prefer it to be without a use of some additional software.But if it isn't possible then the software should be pretty light-weight and not consume a lot of CPU/RAM. Thank you for your help.
    PS: I DON'T intend to buy a multimedia keyboard for that.
    Click Shortcut tab.
    Click OK/Apply.
Mar 08, 2015 | ASUS KB73211 Wired USB Keyboard OEM
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
I have a Micro Innovations KB730/Kb740X key board. and scine I upgraded from Vista Ultimate to Windows 7 Ultimate, the extra buttons and scoller do not work. it functions as typing key board only. Is there...
Are you saying that everything worked under Vista? As far as I know this keyboard has not had an up to date driver since Windows 2000. When you do not run the driver the scroller and the top row of buttons will not work but the other features will work.
When you do run the old driver the scroller will work, the some of the top buttons can be assigned to other functions but some cannot. Also, when the driver is running the forward and back buttons only work for Internet Explorer.
Dec 20, 2010 | Micro Innovations Web Access Pro Keyboard
Need to restore F1 word function in word 2003
  1. On the Tools menu, click Customize.
  2. Click Keyboard.
  3. Click Reset All.
Note: Reset All removes your customized shortcut key assignments and restores the original Microsoft Word shortcut key assignments in the selected template or document.
Nov 17, 2009 | Dell Latitude D505 Notebook
Where is the turn on button for my compaq persario 700
FN, bottom left plus one of the F keys with the wireless symbol
Jan 22, 2009 | Compaq Presario 700 470024-192 Notebook
Adobe Photoshop CS3 Extended Automation Action set won't play
hey, there are three ways in which u can just play actions:
1)just select an action by left clicking it(actions will be located in the actions pallette.) and hit the play button on the actions pallette.
2)just ctrl+click the action in the actions pallette.
3)u can also assign a keyboard shortcut to it.Go to edit menu>keyboard shortcuts>(shortcuts for) drop down menu>choose pallette options. on the top of pallette menu are actions. click it and assign a keyboard shortcut for it.
4)to stop it, just select the action and click on the stop button on the actions pallette.
I think u have not selected a particular action to play.Please do it and see.THANK YOU!!!!!
Jun 27, 2008 | Adobe Photoshop 7.0 for PC
Photoshop 7.
4)to stop it, just select the action and click on the stop button on the actions pallette.THANK YOU!!!!!
Jun 15, 2008 | Adobe Photoshop 7.0 for PC
Identifying & using grey buttons
Those are shortcut keys. The half moon puts your computer in standby mode. The envelope is email and so on. You need to have the program for your keyboard running, ie: logitech setpoint to use these keys then you can press them and see what they do. It's fairly easy to figure out from that point.
Oct 24, 2007 | Packard Bell Multimedia Keyboard...
Compaq keyboard
my keyboard just stopped working. i tried troubeshooting but it hasnt helped.
Oct 21, 2007 | Compaq Keyboard
Compaq Presario 5000 PC Desktop Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
