Question about Canon Pixma iP6000D InkJet Photo Printer
Printer will not print
Everytime you send a print job you get the message saying that the paper output tray is closed but it is not and there are no paper jams. What would be the next thing to check?
  • 57 Answers
Try Closing and opening the paper output tray then press resume button on the printer while the printer is powered on,check the paper feeder ensure that there is nothing jamming up,if this doesn't work then let a canon technician have a look at it, the problem is minor.Hope you succeed
Posted on Nov 27, 2007
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
HH
Aug 12, 2009 | HP LaserJet 5p Printer
Paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Jun 18, 2009 | Canon MF8180C Color Laser MFC Printer
The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Mar 23, 2009 | Canon Pixma iP4500 InkJet Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
247 people viewed this question
old marine
old marine
