Question about Tappan TMS062E1 Microwave Oven
Not turning My Tappan's turntable won't turn.  It tries to, turns a bit, sometimes does turn, but mostly no turning.  Any easy solutions?  The bottom isn't dirty or gunky.
R u putting heavy stuff on it? if not, then its probably how it is and u should exchange it.
Posted on Nov 27, 2007
Panasonic convection nn-cd9975 turntable turns sometimes and not other times.
Most likely a broken turntable drive coupling or a sluggish motor. The coupling has a D shaped hole inside to keep it from Slipping on the shaft, so Try to turn the coupling by hand, if you feel it slip or it is very easy to turn, it is probably a broken coupling.
May 25, 2017 | Panasonic Microwave Ovens
Oven heats, but light, fan and turntable do not come on.
Hi Ted
many microwaves have safety mechanisms to reverse, or stop the turntable if it senses resistance to the turning. This is done both because
  1. the turntable is usually driven by a small motor with a gear reduction transmission to get more torque on the glass platter and your food, and if something resists the turning, it can damage the gear train or belt if it keeps running.
  2. if you have something with liquid in it and it hits a wall, it could tip over, possibly spilling scalding liquid all over and maybe surprising the person who opens the door.
In some cases, it'll just stop and then try again the next time you run the microwave. The banging on the case sometimes turning things back on suggests that either something in the turntable mechanism is awry, or that there is a common hot wire, ground loop, or possibly fuse for the light/fan/turntable.
the manual for the oven doesn't really say anything about this.
You can see generic intructions on looking for an internal fuse here
Panasonic Microwave NN CT552W has no power plug fuse ok Has it got thermal... . Please, in particular, make sure you unplug the oven before opening anything. This is one of those devices where defeating the interlocks and having it turn on can seriously hurt you.
With regard to the turntable, in particular, it's really easy over time for exploded spaghetti sauce, spilled cocoa, and overmelted butter to have run down into the indentation in the middle of the bottom of the oven cavity. Remove the platter. Is it clean in there? Does it look like the 'this person never flosses' picture for mechanical rotors? If so, start with some kitchen cleaner and a washcloth damp (not soaked) with hot water. Let the cloth steam /warm the area a bit, wipe it down. repeat if necessary. If there's a lot of cruft built up there, that could be keeping you on the edge of safety shut-down.
Good Luck!
Nov 24, 2015 | GE JE1140 Microwave Oven
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Aug 02, 2012 | GE Microwave Ovens
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
GE JVM1860CD001 turntable does not turn. Buzzing sound. Sometimes sensor error, close door. Heats and seems to work most times.
If this is an old unit. Unplug it. Take all of the outer screws off and remove the metal cage. Turn on side and look on the bottom at the rubber band drive. It might be wore out of stuck. Try to turn it manually.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is still working but not rotating, what is wroong with it
There's a turntable motor in the bottom of the oven that drives a turntable support directly in some models, and a plastic coupling that rotates the turntable in others. Turntable motor failure is common, or there could be connections in the power to the motor that have gone bad. Sometimes the plastic of the turntable coupling cracks, and the motor shaft turns but the turntable doesn't.
You can check a turntable motor with an ohmmeter. A good motor will show fairly low resistance (a few hundred ohms or less) between its terminals, while a very high or infinite reading means it's bad. In most models of oven you get at the motor through and access panel on the bottom. Replacement motors for many brands are available, although they're not always easy to find.
It may be more economical to replace the oven if it's a basic counter top model. They are under $50 these days, and a replacement motor might cost $20 or more. Of course, you can continue to use the oven even if the turntable doesn't, you'll just need to turn the food yourself occasionally during cooking.
Hope this helps. Thanks for using Fixya!
Mar 08, 2010 | Microwave Ovens
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
Don't know how to turn off the turntable
Turntable usually automatically switch off. If it is continuosly running check the related relay driving circuit.
May 02, 2009 | Tappan TMS062E1 Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Tappan microwave from 1995
check with or call them toll free @ 1-877-894-0035.
Aug 23, 2008 | Tappan TMS062E1 Microwave Oven
Microwave Ovens Logo
91 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
