Question about Acer TravelMate 2451WLMi Notebook
I need guide about the buttoms in the front - Acer TravelMate 2451WLMi Notebook
  • 57 Answers
Try the Acer website and check the support for your model see if you get any where with that
Posted on Nov 27, 2007
I wonder what is the POWER buttom near the shift gear on the Prado type S est 1997
It changes the way the transmission shifts. The shifts are more aggressive and it stays in lower gears longer.
Feb 24, 2012 | Toyota Land Cruiser Cars & Trucks
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
1 9
HDD Led + in pin 1
HDD Led - in pin 3
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
I started a wash cycle, needed to add more laundry, press the pause/cancel buttom twice, now I can't start it again. When I press the start buttom everything goes blank, all lights go off
Remove the power plug and keep aside. Keep the sart button pressed on to discharge. After 15 minutes switch on the washer while holding the pause/cancel button.
If the set does not come back to life it iis possible that the main board has encountered some errors.
Repeat the procedure after some time.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Microsoft key codes on buttom of laptop not accepting it on microsoft works, it has limited me on alot of things. Bought pc from pc world last month??
it may have different code. contact pc world....cuz buttom of ur laptop is the code of microsoft windows. so contact with pc world hope they will guide u.
Oct 25, 2009 | Microsoft Works 8.0 for PC
Jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
Apr 24, 2009 | Computers & Internet
Toner cartridge needs replacing in brother hl-20
if you want to replace your toner,
First you just need to open your front cover and pull out the toner and drum.
after that, push down the blue buttom on drum and pull out the toner. Then replace the new toner into the drum.
finally, just push back the drum and toner back into the printer.
Apr 01, 2009 | Brother HL-2040 Laser Printer
Start buttom doesn't work
Okay, it does sound like your membrane keypad is worn out at the Start pad.
It may be available separately as a key sheet or already attached to a new plastic frame.
In case it comes as a key sheet and if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
LG's Latin American Wen sites are here.
Dec 16, 2008 | LG LRM1250 Microwave Oven
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
Acer TravelMate 2451WLMi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
