Question about RCA D61W20 61" Rear Projection Television
Tv D61W20 I have a RCA D61W20 61 in. and it will not come back on, I had some one look at it and they said it was the High Voltage Sweep Panel burned out. But when I call around to try to find part no one klnows what that part is they say they have a N. W. Circuite Board is that the same thing?
  • DrPohl Dec 01, 2007
    Same tv, front green LED flashes 5 times and 9 times, then repeats with no power up.
    Genius:
  • 2,920 Answers
So basically your power supply is out?
Posted on Sep 03, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
No picture no sound
Most common cause is bad high voltage transformer and the sweep transistor just in front of it---only generic parts are available for this set--cost usually under 40 dollars but for a 27 inch (what is listed here) hardly worth fixing.
Jun 11, 2012 | RCA 27V530T 27" TV
Toshiba 50A61 have sound but no picture - all fuses check okay
Not too many--if sound is developed from the set and not a surround system the set will blank the 3 picture tubes for a few reasons:
Voltages missing at the tubes (high voltage or screen voltages etc)
There is a loss of vertical sweep or horizontal sweep--set will do here this to prevent an INSTANT burn mark on all 3 tubes.
One thing you can try to look for is to see if the filament in each tube is lit---rather dim as 6.3 volt one---if lit the above reasons are your problem.
Without a meter, a schematic etc not much more you can check.
You should hear a faint whoosh sound when you power the set on--the high voltage coming up.
Jun 07, 2012 | Toshiba 50A61 50" Rear Projection...
Why is my tv cutting on an off
If it is a RCA 36V550T do you hear a high pitched sound from set before you try to turn it on?
The model indicated is well known for the High Voltage transformer and or a sweep transistor failing.
The transistor is easy to check with a ohm meter and if shorted 100% chance it and the transformer are both bad (usually just the two parts)
Mar 26, 2012 | RCA 36V550T 36" TV
How do you stop the tv from ringing? I turn it off and it stops but starts back after you turn it back on.
This is a bad capacitor or high-voltage transformer/power supply that will soon burn out. An ohmmeter will be needed to find the faulty capacitor or high-voltage transformer/power supply.
Jan 10, 2010 | RCA HD52W58 52" TV
50' rca projection tv
your high voltage splitter is probably bad, or you high voltage flyback transformer (deflection board). not sure of your model #, is it correct? It may be a lamp but you shouldnt smell burning. You can unplug and let it discharge and find where the burnt up parts are to find your problem. Follow your nose, it always knows!
High-voltage can hurt/kill you.. be very careful
Jan 23, 2009 | RCA L50000 50" Rear Projection Television
Burning smell
the power source is trying to start and it sint. the lamp is done with because thiese tvs need high voltage. its probably melting pallastic around it . get rid of this, much money to fix up and or try getting itn fixed if stiill have legeble warranty
Jan 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA TV
Look for bad solder connections on the solder side of the board: You have to take board out of the plastic and slides out. Look around the high voltage transformer pin connections and large transistor associated with it and all connections associated with it too. Use magnifying glass. Could be hard to see. You could also shotgun the whole section by just soldering all associated connections. Look for burned connections also.
Dec 27, 2007 | RCA F32650 32" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Horizontal scanning does not work
You have high voltage. Horizontal sweep is not working. Mostly we see shorted sweep transistor. Mike
Jul 03, 2006 | iiyama Vision Master Pro 510 22" CRT...
RCA D61W20 61" Rear Projection Television Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
