Question about Apple Cell Phones
I need a help of 4ukey for registration code please send me the code i need to register my software and i want to use for my apple i phones please send me the code now
SOURCE:
otacon
  • 1950 Answers
SOURCE: Locked i Phone
All you need is here.
http://iphone.unlock.no/
Posted on Mar 31, 2008
SOURCE: ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Posted on Apr 30, 2008
SOURCE: 25802GE3-A Phone -Needs Registration
Remove the batteries from the handsets and wait 30 seconds and then place them back in. It will allow you to register them again.
Posted on Aug 18, 2008
SOURCE: My cordless phones need to be registered
Press menu button, the LED readout should say "press pager button and wait for beep".
I have a GE21900FE1 and it worked perfectly
Posted on Dec 03, 2008
mattdehat
  • 1528 Answers
SOURCE: pls send me registration code . my IMEI No: 356640001115685
do not post imei numbers people can use them to clone a stolen phone
Posted on Sep 16, 2009
Boldbeast recorder 3.40 register code
I want registration cod of boldbeast callrec for Nokia E72
IEMEI:- 353784042505141
Email- akmfun@gmail.com
Apr 01, 2013 | Cell Phones
Register code for boldbeast 3.4
my phone is Nokia E-63. Pls send me Nokia Bold beast Recorder v3.4 serial key...
IMEL: 354329046167495
E-mail : prodip.fin@gmail.com
Sep 03, 2012 | Nokia E5 Cell Phone
HOW TO GET BOLDBEAST RECORDER REGISTER KEY
my phone is Nokia is N8. Please send me boldbeast recorder v 3.40 imei no-352847056297953
Jun 06, 2012 | Nokia N79 Cellular Phone
Please send me my registration code for Boldbeast Recorder 3.20 my IMEI is : 351661054509975
please send me my bold beast call recorder registration code to enddyjohn@yahoo.com,enddyjohn@gmail.com,or enddyjohn@hotmail.com.my IMEI NUMBER IS 352057025245071
May 12, 2012 | Cell Phones
Boldbeast software recorder registration code
BoldBeast_nokia Call_Recorder-3_30_0sisx I want register code for Nokia E72 IMEI:357895041596703 Please send to my mail thats register code THANKS. rm08793@mail.ru
Feb 21, 2012 | Cell Phones
Register code for boldbeast 3.10 serial number imel: 355949040214602
Hello and Welcome to FixYa!
Sir if you have misplaced your code, in case you have bought the Software then you can provide a proof of purchase and they will give you your code in return.
But IF you are searching for a free key/serial/crack/codes this isn't the right place, as FixYa strongly prohibit such type of activities and keep a record of its customers and experts along with their IP's to avoid any miss use.
I hope you understand.
Concerned, Uzair
Dec 14, 2011 | Nokia E5 Cell Phone
I want registeration code for boldbeast call recorder for nokia C5-00. IMEI is 354847048044917
This is your master code 0334250076 , if anything goes wrong please let me know. Thanks
Sep 10, 2011 | Nokia C5 Cell Phone
Cannot re-register Vertus Fluid Mask software, which I already own
Hi aaliceronm,
Please follow the instructions below on how to register/activate your Vertus Fluid Mask software.
Vertus Tech provides two ways of registration/activation:
Fluid Mask 2.0: In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three months).
Fluid Mask 3.0: For Fluid Mask 3 they offer two ways of registration and activation of your full Fluid Mask license:
Online registration:
This option requires an active internet connection on the machine on which you are installing Fluid Mask.
1. If you already installed the trial version of Fluid Mask please open Fluid Mask and go to > Help > Register.
2. Fill out the registration form and insert your serial key. The serial key should have been sent to after you placed your order for Fluid Mask 3 and has the format
01AXYZB0B123F123CDA7121234567AF123
Please make sure you copy/paste the serial key into the serial key field to avoid typos or mixing up digits and letters like 0 and O etc.
3. Click on the button to send the information.
4. The registration takes a few seconds. If it was successful you will see a pop-up window confirming that you are now registered.
5. You can either copy and paste your information from there into a file or to create an e-mail.
6. In addition you can see the message "You have a full license" when going to > Help > About Fluid Mask.
Registration by e-mail:
3. Click on the button to send the information. The registration takes a few seconds.
4. If Fluid Mask cannot detect an active internet connection or could not complete the registration for other technical reasons, then Fluid Mask will display your registration information in a new window.
6. Please send the complete information displayed to registration@vertustech.com. It is important that the information we receive is complete and correct.
They will process your registration as soon as possible and provide you with a license code by e-mail. You can then use this license code to activate your full Fluid Mask license under > Help > Register in Fluid Mask 3.
^return to top
Do I need an active internet connection?
Fluid Mask 2.0:
In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three month).
Fluid Mask 3:
Fluid Mask 3 does offer an online activation. For those users who don't want to connect their workstation where Fluid Mask is installed to the internet we offer an activation by e-mail, too. Instructions are displayed in the software during the registration process.
Hope it helps.
Thank you for using FixYa.
Jun 30, 2011 | Computers & Internet
Cell Phones Logo
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
