Question about HP Photosmart 3310 Printer
HP Photosmart 3310 does not recognize paper in tray
HP photosmart 3310 all in one printer cannot recognize that there is paper loaded in the main tray. Is there a sensor or something that might need to be replaced or repaired?
  • 3 more comments
  • fedup1 Nov 28, 2007
    I've tried loading 1 page at a time up to 40 pages and the printer still shows out of paper.
  • Anonymous Feb 11, 2008
    The printer won't recognize that paper is loaded. The only thing I can do is move the paper and try again until it finally recognizes it and prints.
  • codocro Apr 23, 2009
    I have the same problem with my HP Photosmart 3310. It fixed itself when I replaced an ink cartridge (coincidence) and worked for about 4 months and now is back to "out of paper".
  • Anonymous Mar 12, 2014
    I have inadvertantly damaged the rear paper roller sensor (a small bakelite module with a sensor arm.) Need to replace it.
  • Anonymous Mar 30, 2014
    how can I fix it.
    Master:
  • 474 Answers
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
Posted on Feb 16, 2008
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
My HP Photosmart 3310 will not pick-up A4 glossy photo paper in the main tray. 6x4 works fine in the photo tray
Your printer might have opening area for clearing paper jams, also on that area there are some rounded parts that do actual picking-up of paper. Clean those parts with some non-agresive cleaning agent and try again.
Mar 06, 2011 | HP Photosmart 3310 Printer
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
I don't know where the "photo tray" is located!
You have to specify the paper type in the printer properties. Look in the printer properties folder and navigate to the paper type or options. You'll find a place where you can specify what kind of paper you have.
Mar 15, 2009 | HP Photosmart 3310 All-In-One InkJet...
Paper tray won't go back in
go to the back of your hp photosmart printer and there is a small compartment.
open it up and there will be a piece of paper there pull it out and your paper tray should go back in.
by aamir ahmed
Mar 11, 2009 | HP Photosmart 3310 Printer
HP 3310 All In One
Don't know if this will help but. I had a HP printer that would not feed the really heavy weight photo paper, I just backed down a couple weights and it worked fine...
Jan 23, 2009 | HP Photosmart 3310 Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Printer doesn't recognize paper
if u remove papaer from feeder u should c the paper sensor this sensor is located deep inside the printer try to move it (mayb stuck) with a screw or any thing tall then try to aprint again this sensor is responsible for detecting the presence of paper
Nov 28, 2007 | HP Photosmart 3310 Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart 3310 Printer Logo
846 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
