Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Check the outer washer ring for mold deposition. There is no way to remove this mold and it is a health issue. GE should recall this product.. absolute **** and it is not a GE specific issue but all the front loading washer have this problem
Was this helpful?
Yes
No
Popular Solutions for General Electric WBVH6240HWW
i have a front load washer that needs a new door gasket, we have the gasket but need to know how to...
(More)
i have a front load washer that needs a new door gasket, we have the gasket but need to know how to get the front off to put on the new gasket.
the door is locked and I can not get the power on to unlock the door - i can hear the motor run when...
(More)
the door is locked and I can not get the power on to unlock the door - i can hear the motor run when it is plugged in but nothing is moving or opening how do I get the door open- this is a front load washer.
