Question about Canon PIXMA MP780 All-In-One InkJet Printer
Red will not print
I have dep cleaned many times but the red ink will not print. I have replaced the ink in case it was a problem with that particual ink cartridge but same problem. Should I buy a cleaning kit? This is a replacement machine for the one I had under warranty and only came with a 90 day warranty (Staples voided the 1st warranty when they replaced the machine- bogus)
  • 1 more comment
  • pleiad Nov 27, 2007
    I also have color printing problems. I have cleaned, auto aligned the print heads, manually tried to align print heads, refreshed..everything and still the same issues. Sometimes it will come out of it on its own and just start printing colors again. But so far nothing. Maybe the print heads are gone?
  • SolutionsCRS Dec 20, 2007
    I have also deep cleaned and aligned heads etc, and cannot print RED. Anyone have an answer?
  • Anonymous Dec 21, 2007
    Very Poor color printing, even after cleaning etc. Multicolor image prints mostly faded yellow...ready to toss the practically new printer!
  • 2,427 Answers
TAKE THE INK WELL OUT AND BOIL IT IN ALCOHOL (rubbing alcohol)
replace it and run a few deep cleaning
that should works fine
this printer ink well clogs and stadders quite often i had to boil man almost once ever cpl months
PLEASE NOTE THE ABOVE METHOD IS NOT CONVENTINAL BUT IT WORKS
other than that you can replace your ink well
Posted on Dec 31, 2007
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
I didn't use my printer for quite a long time. When I wanted to print with it, it qould only print in green. I changed all the ink catridgesbut then it only printed in red. It won't print in any color...
In many cases after a printer has not been used for a long period of time, the ink will become dry. Most printers will have a "Clean print heads" option. Also trying to print a page or two may resolve the issue.
If it continues however, the printer may need replaced. Dried ink can block the print heads and in some cases can not be unblocked without taking the printer apart, which will void the warranty.
Nov 20, 2010 | HP Designjet 110plus nr InkJet Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Red does not print. I have deep cleaned several times, it still not print.
red is a combination of yellow and magenta ink, check if you still have the color ink, or clean this unit first otherwise you need to replace the color ink
hope this helps
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Red colour not printing - all others OK
for that you will have to open the printer and remove the head unit,and clean it with moist tissue and alcohol. thanks.
Nov 07, 2008 | Brother DCP 115C All-In-One InkJet Printer
MP360s
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Besr regards,
Rosener Guyano
Nov 22, 2007 | Canon i350 InkJet Printer
Red and Yellow not Printing at all.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Oct 16, 2007 | Brother MFC 420CN All-In-One InkJet...
Red ink not printing
the channels for the ink to flow are really minute [small] if ink dries up in them it can take some time to soften it up before anything will flow. try deep cleaning the printhead.
Jan 07, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
