Question about ASUS MW221U LCD Monitor
Screen Freezes then goes black!
This is an 2 weeks old screen, couple of days after purchase it started to freeze the picture and then the screen fills with a black color till its completaly black and usaly some mins later its fine again :S ( sometimes longer hours )
Got dual monitors conected so its not a pc problem defenetly a motitor problem :(
  • 2404 Answers
SOURCE: screen goes pink and green starting with a few pixels
Best thing to do, try a different known working monitor to hook up to the computer. If the screen works and doesn't change colors then you know its the original monitor that is bad.
If you hook up the known working monitor and the same problem happens then you know its the video card that is bad and the video card would have to be replaced.
Posted on Aug 23, 2009
  • 466 Answers
SOURCE: My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
Posted on Oct 22, 2009
  • 11361 Answers
SOURCE: The monitor screen go to black after 5 seconds
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Posted on May 16, 2010
  • 732 Answers
SOURCE: We have just purchased this MT276HE monitor by
doremo, Try ATI 5700 card on old Win XP system with Acrobat 9.2 If problem ceases to occur, I would blame Win-7 for your problems!! 12fixlouie
Posted on Oct 21, 2010
  • 220 Answers
SOURCE: computer screen does not fill monitor screen -
Please check the resolution settings which should be at 1366><768 or 1920><1080. Also check that you have not slected 16:9 aspect ratio accidently. Samir
Posted on Feb 07, 2011
  • 317 Answers
SOURCE: monitor is displaying colorful verticle
Try to trouble shoot your video card or unattached your video card from your board and clean the bronze part with a pencil eraser and re attach it again and try if it will work if doesn't the problem is in your video card why because you already used two different type of monitors but still the problem is there..
Posted on Jul 05, 2011
0 characters
1 Points
No signal for acer screen all the day....
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
May 02, 2014 | Acer Computer Monitors
Al2416W black screen (picture only lasts for 0.5 seconds)
After two years, it will more likely to have failed caps in the power supply, common problems in ALL monitors these days, theymade them to fail after a couple years, does not matter what brand, see examples here:
Post back what you find inside.
Jan 23, 2010 | Computer Monitors
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computer Monitors
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor cold start issue only as #2 monitor
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
May 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
My Monitor Is Going Crazy
have you tried to check if your pc is infected by virus? you should update your anit virus.
Mar 24, 2009 | Compaq Computer Monitors
MAG Innovision LT2219WDB monitor will turn on -picture up clear as ever and 2 seconds screen goes black, turn it on and off screen comes up clear as always and 2 seconds goes black. will not keep the...
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Feb 24, 2009 | Computer Monitors
are you sure that its your screen? try another screen if it does it. if not, then try using a differant res and refresh rate.
beings that your screen freezes and then goes black on exit.
I would say, your game is heating up your computer by useing stuff that usually dont get used. try removing the cover and carefully cleaning all heat sync's so it can breath.
if the problem continues, please report back, with more info, on what game and what model system you have with operating system. also if you added a video card.
Apr 09, 2008 | Computer Monitors
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Black Screen-No picture
Normally when an LCD monitor goes black, it is because the inverter goes out (which essentially is the backlighting).  To verify this problem, hold a flashlight up to the monitor while it is turned on and see if you can "see" the picture.  If this is the case, it could be repaired, but realistically, the cost to replace it might be cheaper (and you would probably end up with a larger monitor to boot).
Jan 01, 2008 | E-Machines eMachines Monitor E15T4
ASUS MW221U LCD Monitor Logo
156 people viewed this question
Top ASUS Computer Monitors Experts
 Mike M
Mike M
Level 1 Expert
Level 1 Expert
Are you an ASUS Computer Monitor Expert? Answer questions, earn points and help others
