Question about Canon BJC 80 InkJet Printer
Error light stay on
The error light stays on even when reset
  • 4 Answers
Probably needs a new printhead. try switching with a good if know a friend with bjc 50/80/80. all are compatible.
Posted on Mar 16, 2008
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
Wpn824NA Not working
Hello.
If the test light on the router stays on after 20 seconds, even after turning off the router and back on it stays lit, it means the router has a problem.
What you can try to do is reset the router to factory settings:1. With the router powered on, hold down the reset button on the back of the router for 20 seconds until the test light on the fron panel turns on.2. Release the reset button and wait for the router to restart and become stable.
If the test light does not stay on anymore, the router should be ok, you need to set it up again though.
Hope this helps. Glad to be of service.
Nov 24, 2011 | NetGear Computers & Internet
My router isn't working. all the lights stay on
Make sure you're using a paper clip while pushing the reset button. Also the router has to be on while you're pushing it. Hold down the reset button for at least 30 secs-1 minute
Jul 09, 2010 | Linksys Wireless-N WRT150N Router
Air bag light stays on. can i reset it 2003 hyudai accent
Dealer scan tool is required to clear code. even if you fix the airbag error, the light will remain lit until it is cleared with scanner
Oct 20, 2009 | 2003 Hyundai Accent
1992 Honda Accord Lx 2.2L D4 light comes on at start up and stays
Hello , It is prob the OD. solenoid engageing to early or intermittently , or the locking converter is not locking and passing all torque to the wheels
Jul 25, 2009 | 1992 Honda Accord
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
''Check Engine Soon'' light Stays On.
Must have engine computer scanned to get codes and determine cause of check engine light. Low tire light probably needs reset. Open passenger door and remove panel on side of dash. Reset switch should be located in that compartment.
Mar 31, 2009 | 2001 Buick Century
It should only be dealt with not just certified mechanic but electronics expert at volkswagen itself. in this case i want to say, it needs Light Procedure reset! or priority reset. Mainly it is a code error in the jetta!
Hope it helps.
Feb 16, 2009 | 2004 Volkswagen Jetta
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Canon BJC 80 InkJet Printer Logo
105 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
