Question about Samsung SGH-D900 Cellular Phone
Case Creaking My case is making a creaking sound, as if there is a gap between the slider and the bottom half. if i hold the top down with pressure and slide up and down the problem is over. It makes the sound when the slider is up or down.
  • 175 Answers
That creaking sound is the spring maybe its been dislocate or cut in a half. go to your nearest service center if they can replace that spring cuz' if you wont get that spring out it could get worst cuz' it could damage your flex cable.
peace!
Posted on Nov 27, 2007
Hear a creaking noise under the dash on the driver side, it goes away if i accelerate or hit the brakes. it seems to be vacume related. could it possibly be the brake booster. It makes the noise constantly...
The exact nature of the creaking is important, and you have not provided enough info to narrow down the problem. The only "creaking" noise I have ever heard like that was coming from the front wheel. If it is going "creak -creak-creak" and changes as the car changes speed, I would check that.
Mar 04, 2018 | Buick Century Cars & Trucks
My son has a discovery kids safe....we lost passcode. Can it be reset? Numbers/letters on bottom of safe are: YLBSD-NI 2006 07 12330
The Discovery Kids Safe works slightly differently. When you press the reset button on the bottom of the safe, the code defaults to "1234". To set a new code, Press *, then your four-digit code, then * again.
Emergency Open: In case of malfunction, hold down "WIRE" button and push on the drawer.
Feb 15, 2011 | Discovery Kids Toys
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
When turning left or right steering makes a creaking noise mainly from drivers side wheel, also when stationary drivers side makes creaking noise when pushing down on the wing, after the car has cooled...
This sound is coming from your strut. Sometimes they will get water in the seals, or dirt, and they will start creaking exactly as you describe. This isn't a big problem unless you can't live with it, and if this is the case, just replace the strut on that side. When the car bounces when you press on that side, then you need to worry about that strut, but otherwise, it's ok.
Feb 21, 2010 | 2004 Audi A4
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
Delonghi Magnifica Makes creaking noise when preparing brew unit
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
May 19, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Creaking steering
try topping up the power steering fluid? if not it's the power steering pump.
Aug 30, 2008 | 2000 Audi TT
Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
May 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Samsung SGH-D900 Cellular Phone Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
