Intel DG965RY Motherboard Logo
Posted on Aug 08, 2009
Video controller showing error
Vga is not installing , it is saying system requirement is not enough but i installed the original driver of my system
  • ajay sharma
    ajay sharma May 11, 2010
    How much RAM do you have in your Computer and which operating system you are using
Anonymous
Level 1:
Problem Solver:
  • Contributor 30 Answers
  • Posted on Aug 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
30
Questions
0
Helped
4230
Points
66
Please install the dirver of that particular O.S which you have installed.i mean there is different drivers for diffrent operating systems.
Fatal Error: Msg display - "No
vga driver or directx 9 not installed or curropt
2answers
Vga driver for ibm thinkpad R32 is not available
What Operating System are you running? This link( click here) to Lenovo/IBM's suport site does show video drivers available for all OS's, even older ones, but there is a note in the table on that page that says "Windows 98, Me, 2000 - Note: This AGP driver is required in addition to standard video drivers listed below for Windows 98, Me, and 2000."
Make sure you have downloaded and installed both VGA and AGP for your correct OS and see if that helps.
I have no wireless connection after re-installing xp device manager says :- ethernet controller - network controller :- video controller :- video controller (vga compatable) drivers are not installed...
do you have the driver cd's if yes then you can install it using that because after reinstallation the drivers has to be installed otherwise the system wouldn't work
I try to movies on DVD, it says please install VGA
This is because the graphics card driver is not installed\corrupted. I've you have the driver CD insert it and install the driver for the graphics card. Else go to HP.com and select 'Drivers and download', specify your laptop model and Operating system. Download the drivers and install it.
Please come back and vote for me if this turns to be helpful for you of also if you need more clarifications. Thnx
2helpful
No video output from atapi dvd rw after OS reinstall, cd rw ok
>> VGA controller (vga compatible) error in the device manager
Windows has not found a "good" device-driver for the "integrated" video-controller on your motherboard; it is using the "generic" adapter.
So, trying to download the "SIS Mirage Graphics" software is an attempt by Windows to download a "specific" device-driver that matches your video-adapter hardware.
You might try installing an add-in video-card, to see if Windows will install the correct device-driver, and still boot-up correctly.
Otherwise, take the computer to a qualified technician, for trouble-shooting about your boot-up problem.
I need to load the drivers for the audio and video on my Sager D270s. It's a windows xp and the pnp for the video and audio are below Multimedia Audio Controller PCI\VEN_1039&DEV_7012&SUBSYS...
Connect the system the internet, click your start menu, scroll to control panel and click it. From your control panel, double click system icon, when it opens, click hardware and thereafter, click device manager.
You would see a list of your hardware, scroll to audio, right click on it and press drivers update. The audio driver will automatically be installed from the internet. The same applies to the VGA.
Make sure the internet connection is strong enough to download the drivers, it might not download if internet speed is slow.
Best wishes.
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
[email protected]
Can't install driver
Make sure the operating system is listed as being supported by that driver disk. Typically driver disks shipped with the cameras are not the most up to date and you are better off downloading a current driver from the manufacturer.
I can't reboot after installing Intel VGA driver
hi!
Just try to run in the safe mode 1st and try to fix the problem there.Your video card most probably is a built in with the motherboard and the new video card driver might require you a higher memory.
1.The idea is to restore your original video card driver
2.If your running xp or windows 2000 press F8 to check your sysytem and boot in safe mode.
e-mail me at [email protected]
good luck
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
