Question about Phones
I have a memorex MPH2430 Cordless phone. I cannot get it to connect to the base. Any suggestions
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
SOURCE: phone not connecting
I find that unplugging the base unit power for about 20 seconds, then replugging it, usually clears this problem.
Posted on May 01, 2008
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
  • 650 Answers
SOURCE: I cannont register a ATT 2042 cordless phone to
Are you sure it's a 2042...I found 2402 manual
Posted on Apr 14, 2009
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Posted on Sep 29, 2009
0 characters
1 Points
I have a Uniden cordless phone EZI996, The lights on the base are blinking on & off bright red.
Try the following procedure to reset and re-sync the phone system:
  • Disconnect all units from power.
  • Remove batteries from all handset.
  • Check all phone connections to base.
  • Check the phone connector underneath the base (RJ11 squared plug).
  • Put back battries on handsets.
  • Place handsets on base.
  • Connect base back to power with handset sitting on base.
If that does not fix the problem , then there is an internal fault. In that case call Uniden to arrange repair or replacement.
Uniden support number for your area is prited inside the user documentation.
Dec 05, 2009 | Uniden Cordless Phone
I have no dial tones on our two uniden 5.8GHz cordless phones. New batteries were installed.
Make sure the phone and the phone base is turned on. Check the phone cables at the back of the phone base where you charge your cordless phone. It should be properly connected to the phone jack on the wall and at the back of the phone base. Try unplugging and replugging it back in. If that fails, try changing the phone cable. If still there's nothing, try to connect another phone on the phone line. If you get a dial tone, it means you have a problem with the wireless phone set, if not, contact your phone company.
Nov 11, 2009 | Uniden Cordless Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Mar 26, 2009 | Panasonic KX-TG1033S Cordless Phone
My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Jan 06, 2009 | Vtech Cordless 6041 Phone
Cordless handset phone will not connect to base
A Microprocessor Problem, beyond ecconomical repair.
Sep 16, 2008 | Sony SPP-A2780 Cordless Phone System
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Oct 18, 2007 | GE 25881EE3 Phone
Cordless phone does not connect
I have the very same problem and it was after storing numbers into the directory, although that may not have anything to do with it.
Jan 23, 2007 | AT&T E5908 Phone
Oct 09, 2006 | Sony SPP-S2730 Cordless Phone
Phones Logo
Top Phones Experts
Are you a Phone Expert? Answer questions, earn points and help others
