Question about Konica Minolta PagePro 1350W Laser Printer
Feeder problem the feeder starts to have problem lifting the page recently. instead it will spit the page out of the feeder, causing an error msg on the screen. to manually solve the problem, i have to use my thumb or finger to push at the edge of the paper stack, so that the paper can't be spit out in that direction.
  • hugo2008 Dec 02, 2007
    thank you so much!! i will try it soon!!! you are very creative! :-)
The same thing has been happening to me. I believe that as the machine gets older, soft plastic parts get hard. Your problem is that the soft rubber part that rotates down and picks up the paper has gotten a bit hard. It won't pick up the paper as well as a new soft part. Just look into the back of the feed tray when you print a page. You'll see a sort 1/2 wheel rotate down and try to pull the paper up. What I did to improve the traction of the plastic was roughen it up with some medium grit (150) sandpaper. You can easily remove the front cover by first opening the cover, pull out the cartridge, press in on the side of the cover where it rotates in the printer's body, slide it out. You'll see the 1/2 wheel clearly now - it has horizontal ridges. Use your sandpaper lightly in the direction of the ridges - horizontal. Then, blow out the dust. Put your front cover back on, put in the cartridge and voila - it'll work. Atleast mine has been working fine. This sort of fix works on rubber contact wheels (in a VCR or cassette deck) for a while, but eventually the hardened part will need to be replaced. But see how it works for you. Best of luck.
Posted on Dec 02, 2007
Error no page in Feeder when there are pages in feeder
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
May 05, 2014 | Canon DR-9080C Path-Through Scanner
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
I am using the SCX-4828FN printer. When I am scanning pages from the feeder, not the glass, I am getting a long back line down the page. I have looked for dirt in there but cant see any, actually having...
I dont think you need to open the feeder but usually it opens up by lifting upwards where the paper goes in. It usually needs a bit of pressure to open.
You will see a small piece of glass going across the machine either in the feeder or at the end of the large plate glass when lifting the whole document feeder.
On this glass there will be a mark that needs to be cleaned off. Look closely as sometimes the mark is hard to see. It is commonly caused by using whiteout.
Jun 02, 2011 | Office Equipment & Supplies
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Auto Feed doesn't work. When I press the start button I get an error to open the copier and remove the paper. There is no paper above the glass. The symbols showing are LIFT and PAPER JAM.
There is a mircoswitch which may become slightly bent. The microswitch rides on the left hindge of the feeder inside the covers. When the start button is pressed the feeder may move upward slightly causing the miroswitch to loose contact with the hinge. You can usually reform the arm of the switch and make it work.
Jul 16, 2009 | Canon NP 7130 Black and White Copier
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Feeder Issue
Open up the feeder, remove the two large chrome screws holding the beige cover and lift off. make sure nothing is blocking the rollers or switches. Further disassembly requires a Kyocera or Copystar technician.
Apr 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
Aug 05, 2008 | Office Equipment & Supplies
Konica Minolta PagePro 1350W Laser Printer Logo
376 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
