Question about IBM ThinkPad 770 Notebook
Screen blanks sporadically
Good has become sporadic with the display. Relaced circuit board and backlight, to no effect. Is this a motherboard issue or do you know?
  • Rodd Nov 30, 2007
    Your information is both accurate and unwelcome. I just replaced the screen and the problem persists, which means I was sold a bad screen by an unscrupulous jerk. I already know the bit about plugging in to an external monitor, that is how I determined the initial screen replacement. I was hoping against hope that there was some other detail I had overlooked . . . but I already did the circuit board(not the motherboard). ok?
  • 31 Answers
This could be a video issue or a screen issue. To determine which one try to plug it up to an external monitor. If it does not black out on the monitor then it is the screen. If it blacks out on the monitor then it is the video component of the motherboard. In that case you would most like replace the motherboard.
Hope this helps!
Posted on Nov 27, 2007
Viking fridge top and bottom model#vcbb536rss is beeping sporadically, the display screen is flashing, what is wrong with that? what part we need to check?
high low voltage board were likely not needed
board registers high temp and after a few days of constant high temp alarm will restart
by replacing low volt board all you did is start with empty register also when replacing low volt board they have to be programed for your model
sounds like you need service for your cooling issue
May 31, 2017 | Viking Refrigerators
I took my HP Pavilion dv7-1132nr on vacation with me and the monitor sporadically goes black. I thought it was in hibernation but I cannot get it to go on. I do a hard stop and after about six or seven...
This is most likely either an issue with the display itself or the cable that is inside the laptop chassis that connects the motherboard to the display. The cable can get pinched and unplugged by the screen being opened and closed (if it wasn't assembled properly). This can be about a $200 fix. If it is the display itself cutting out completely, it is typically over $350 to repair through HP. If there is a dark, washed out image that is barely visible, it means the backlight is going out and that is at least a $300 repair.
Aug 23, 2011 | HP Pavilion dv7-1132nr Notebook PC
Screen is blank when powered up and i cant see anything on the screen
Hello.
Connect an external monitor / display to your laptop to see if your laptop's display is faulty.
If faulty, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 24, 2011 | Computers & Internet
Steering becomes difficult sporadically
this could be one of 3 problems .1 are you low on fluid ,2 bad power steering pump.3 bad rack and pinion .
Jun 18, 2009 | 2004 Kia Sorento
Screen will remain blank after mac is turned on sporadically.
the only place i know they fix this is london (shop name micromend ) had the same it is a common fault graphics chip fault
Jun 01, 2009 | Apple 15.4 MacBook Pro Intel Core 2 Duo...
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Screen on HP Pavillion 8000
OH boy! It' service time in the form of replacing the display...accordianman
Nov 29, 2007 | HP Pavilion dv8000z Notebook
IBM 770 screen blacks out sporadically
If you have an external monitor, try plugging up to that to see if it is an LCD screen issue or if it is a video card issue. If the monitor does not show the same symptons then it is the LCD screen. If it does then it is the video card. Usually the motherboard will need to be replaced if it is the video. If the screen, then it will need to be replaced.
Hope this helps!!
Nov 27, 2007 | IBM ThinkPad 770 Notebook
IBM ThinkPad 770 Notebook Logo
54 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
