Tomtom GO 720 GPS Receiver Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Application on my TOmtom go 720
Whenever i update it says there are no updates, even though i deleted my application. There are applications on my computer. can i copy these somewhere so my device shows an application? or can i make update work properly in HOME?
Anonymous
Level 2:
Sniper:
  • Expert 171 Answers
  • Posted on Nov 21, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
171
Questions
0
Helped
88975
Points
358
Connect your TomTom to your PC and open the drive in "my computer". Locate the ttgo.bif. Copy and paste the ttgo.bif onto your desktop (do not skip this step in case something goes wrong) then go back to the TomTom and delete the ttgo.bif. after deleting ttgo.bif open TomTom home. It should then tell you you need a operating system. Let TomTom load the system. You may have to do this a couple of time to fet the latest operating system back onto your TomTom.
How do I update my Tom Tom GPS on computer?
    1. To check for an updated application version do the following:
      1. Connect your TomTom device to your computer and switch it on. ...
      2. If HOME does not automatically check for updates, click Update my device in the HOME menu. ...
      3. If a new application is available, it is listed on the next screen. ...
      4. Click Done.
      More items...
      How do I update the software on my device? - TomTom
      us.support.tomtom.com/.../how-do-i-update-the-software-on-my-... TomTom
    Feedback
  1. How do I update the software on my device? - TomTom
    us.support.tomtom.com/.../how-do-i-update-the-software-on-m...
    TomTomAug 28, 2015 - To check for an updated application version do the following: Connect your TomTom device to your computer and switch it on. If HOME does not automatically check for updates, click Update my device in the HOME menu. If a new application is available, it is listed on the next screen. Click Done.
Dec 25, 2015 • GPS
2answers
It shows a 'X' mark
the other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
1helpful
TomTom Go 720 map activation
No Maps Found usually means the Application on your internal memory is not the latest one, or the map did not download correctly.
Make sure when you select internal memory when updating your device on home, that you update the application as well.
V8351 should be the latest application for your device.
Need to find application for TomTom Eclipes AVN2210p and download
try these steps:
make sure you are logged in to home program
go to www.tomtom.com/10059...make sure you set the HOME program to the default settings
close HOME rename the TomTom file in 'My Doucuments; to TomTom2, then reopen HOME again, log in, and click on update my device again
TOM TOM RED X APPEARS AND UNIT WON'T SHUT OFF
That typically happens as a result of an application update that either downloaded an incorrect version of the application for the device, or the application update didn't complete before the device was removed, or the application it downloaded was somehow corrupt.
Try deleting any application updates that were downloaded into HOME, then delete the application from the device, then download the new application update for your device, and install it to the device. Give it a good wait after it says it has finished installing the application update and then be sure to use the software eject button within HOME before disconnecting the drive.
Otherwise, you probably have a call to TT support in your future where they will likely have you download a utility to clear the flash on the drive and reinstall the app on the device after that
TomTom go720 computer voice stutters street names
Hi Guys,
This is a problem with the application v8.300
if you are using a map v8.XX or higher you will need to wait for the next appilcation update which should fix this.
if you are using a map vv7.XX or lower, you can remove the 8.300 application from your device and download v7.481 by updating your tomtom again, this will revert your application to an earlier version which you can use until the next application is released.
Hope this helps.
Pabs
8helpful
ERROR: 573/#https://home.tomtom.com/shop/onetimeDeviceUpdates: Error from server: You have an invalid version of the TomTom application installed on your TomTom device. To use HOME you need to install the...
Go to My Computer, then the TomTom drive and click explore. Move your Map folder to the desktop. Then, delete everything on the tomtom drive. Unplug it, plug it back in, and start up Tomtom HOME and install all updates, keep unplugging, plugging back in, and installing updates until there aren't any more updates. Then move your map folder back to where it was on your TomTom drive.
Please rate, Thank you!
Wont play voice through my stereo...
The instructions through FM transmitter violated some European regulations so had to be removed. The latest application update removes this feature for navigation - though music is still allowed. Sucks for US customers, not sure if they will release a US only application build to resolve this issue or not.
2helpful
My 720 frozen
• The device hangs in the start screen (splash screen )
14helpful
3answers
TomTom ONE has flashing "X" and picture of TomTom
I found this.
Question: Device shows a flashing cross when turned on.
Answer:
If your device only shows a cross after you turn it on, the TomTom application is not installed or cannot be found.
To solve this, follow the steps below.
Manually remove the TomTom application:
Reset your device.
Connect your device to your computer.
Turn on your device by pressing the power button for 5 seconds.
Do one of the following:
Windows: Click Start > My Computer and then double-click the Removable Disk for your TomTom device.
Macintosh: Double-click the desktop icon for your TomTom device.
Delete all files except the following:
Do not delete any of the folders!
Do not delete the files antitheftw.bmp, lowbatteryw.bmp and splashw.bmp (if present)!
Reinstall the TomTom application:
Start TomTom HOME
Select an option:
I previously updated my device on this computer
I never updated my device on this computer
Click Done and then click Device > Disconnect Device.
Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
