Put
in time, push start and unit runs
for 2 seconds, relay clicks, unit goes off. Cook time on display goes
off and clock time comes back. Bad upper interlock switch and charred
connector
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking...
(More)
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking indicator not lit up on display
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook...
(More)
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook something, it appears to operate but cuts out after three seconds and does not heat anything during that time. Thnaks
the microwave continues with light on and turntable turning despite the time running out and...
(More)
the microwave continues with light on and turntable turning despite the time running out and pressing reset etc.
