Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
EL5 (large) powerhead
I recently started having problems with the large powerhead on my Electrolux Oxygen vacuum. When I turn the brush roller on, it almost immediately kicks out and requires me to hit the reset button. I can only move it two or three times before it shuts off. I have checked for any blockage and there is nothing there that need to be removed. This seemed to coincide with the installation of a new hepa filter and bag. Any suggestions?
  • Anonymous Mar 27, 2008
    The power head stopped working after I caught a wire in it. I removed the wire completey, checked the belt, and prsesed the rest button. Still not working. Any ideas?
    Problem Solver:
  • 12 Answers
Common problem the reset itself is bad and needs to be replaced
Posted on Aug 03, 2010
Wand connections are burned
Posted on Feb 23, 2008
  • 1,673 Answers
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Posted on Jan 31, 2008
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Electrolux central vac powerhead (N106M) frequently tripping built-in circuit breaker. It seems to be only when pushing in one direction, why would the motor draw more current in one direction? (it doesn't...
Have you checked the roller brush. Thread, string, and hair wrapped around the brush will create stess on the motor, resulting in overheating and shut off. Clean the brush and try.
Jan 26, 2011 | Electrolux Centralux Vacuum
Hello, My Electrolux Oxygen motorized brush stopped working. How do I determine if it is the switch, a belt or something else that is causing the motor not to work?
Hey Lee,
We had the same problem and after taking it to a service guy who didn't even want to LOOK at the vacuum, it occurred to us to plug the powerhead brush directly into the handle and it worked! So, we were able to determine that the problem was the tube - not the brush.
We ordered a replacement tube.
Hope this helps.
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The powerhead brush died. The vacuum works just fine, but the brush doesn't.
there could be 2 reasons for this problem.
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
good luck
I have a 15 yr old electrolux genesis upright vacuum cleaner that I can't get the roller out, to replace the belt.
There are two small screws at the end of the brush roll on some of these. There is a bearing block recessed into the housing at a slight angle to help tension the belt, so it comes out at an angle as well. It often fills with grit and you must clean the grit out carefully without damaging the blocks or housing. Sometimes WD 40 helps is the area has any rust build up. Then work a large screwdriver under one end the brush for leverage being CAREFUL not to damage the brush housing. Do not soak with WD40 as it will also get into the brush roll bearings
Jun 09, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
May 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
F7452900 the brushes won't rotate during floor cleaning
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Apr 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Parking position
I think it only works on the advertisements.
Nov 26, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
786 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
