Question about Adtran NetVanta 1224R 24-Port Ethernet Switch
SNMP Hello, i have a frame relay circuit connected to a netvanta 1224r to the FR interface. When I do an SNMP walk or a device query to populate my database, the response is telling me that the frame ckt is connected to e03. The AOS is 13.08.00. Can anyone help me?
0 characters
1 Points
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Networking Hubs & Switches
Port getting flaps
sounds like some sort of keep-alive problem.
Try using
switch(config)# debug snmp packets
this will show you what is causing the line protocol to drop. you need to be connected to the console to see the output for this and turn it off when your done.
un debug all
good luck.
Jun 06, 2012 | Cisco Catalyst 4948
My 5 port snmp hub card is not working. It is unable establish connection with the other system. is there any way to solve this?. Otherwise kindly help me to get new card from indian sources. Looking...
hi friend, if your hub is not working with any system. then, you go for system repair shop. they will help you. they will fix your problem. reach to your nearest electronic service center.]
or you r interest to buy new one. then, go for any brand company.
Jan 31, 2011 | Levelone - FNC-0600TXM V2 5 Port SNMP...
Hello i want config snmp in 3com 3300MM but i can not set it please help me thanks
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 23, 2011 | 3Com SuperStack II 3300 SM Networking...
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 -"
interface 50
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address
ip helper-address
tagged 49-50
no untagged 47-48
vlan 2
name "Voice"
untagged 47-48
ip address
ip helper-address
tagged 1-46,49-50
ip route
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Command Line Help
Under "Product Information" it says "Remote Management Protocol: SNMP, HTTP". I am guessing the HTTP management console does not give access to a CLI.
Problem solved. :)
Jul 14, 2009 | EMC DS-24M2 (DS24M2)
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Can we able to trunk one vlan to another vlan
interface GigabitEthernet0/1
switchport access vlan X
interface GigabitEthernet0/2
switchport access vlan Y
interface GigabitEthernet0/3
description trunk port
switchport mode trunk
switchport trunk allowed vlan X,Y
Aug 19, 2008 | Trendware 8PORT SMART POE SWITCH SNMP VLAN...
Adtran NetVanta 1224R 24-Port Ethernet Switch Logo
Top Adtran Networking Hubs & Switches Experts
Brian Sullivan
Brian Sullivan
Are you an Adtran Networking Hub and Switch Expert? Answer questions, earn points and help others
