Question about Computer Associates BrightStor ARCserve Backup Release 11 for Windows Agent for Backup Agent for MS Exchange Premium Add-On for PC
ARCserve Backup to disk Solution
Is it possible to configure ARCserve to backup to disk?
Cornell
  • 45 Answers
Yes it is possible. You had to create the new media pool and added that in to particular new or current device group. and schedule your backup on that media of that device group . Cheers Parveen
Posted on Feb 03, 2008
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Tip
Here are some of the best practices to take into consideration in any backup &...
Here are some of the best practices to take into consideration in any backup & recovery system:
  • Usually perform system state backups of your servers frequently. Each computer on a Windows network has a corresponding computer account in Active Directory. Like a user account, the computer account has an associated password. The difference is that the password is assigned, and periodically changed, by Windows. If you try to restore a system state backup that is too old, the computer account password that is stored in the backup will no longer match the password that is bound to the computer account in Active Directory. As a result, the machine won't be able to participate in the domain. There are workarounds, but it is usually easier to just make frequent system state backups of your servers, & use these backups to recover the servers when needed.
  • Always backup the data, the server's operating system, & the applications installed on the server. Although it is true that, if a server fails and you need to perform a full recovery, you can reinstall the operating system & the applications & then restore any data. However, time is of the essence when trying to recover from a crash. It is much faster to restore everything from backup than it is to manually install an operating system and a set of applications. More important, it is often difficult to manually configure a server so that it matches its previous configuration. Backing up the entire server ensures that its configuration will be exactly as it was before the crash.
  • Periodically test your backups to make sure you are able to use them for recovery when the disaster strikes. Always remember that we perform backups in order to be able to restore from then when we need to. So, we have to make sure our backups are usable.
  • For some applications (for example, Microsoft SQL Server, Microsoft Exchange Server, Lotus Domino Server, ... etc), a file-level backup is insufficient. These applications usually utilize open databases that need a special backup agent to back them up consistently while they are being in-use. Usually make sure that you are using the correct backup agent needed by your application.
  • While you should keep backups off site, consider waiting until the end of the business day to remove the previous night's tapes from the building. This way, if your server fails early during the day, you will not have to wait for hours till you can get the tapes on-site again & start the recovery.
  • Construct your backup architecture in a way that avoids (at least as much as possible) having a single point of failure. If possible, have a backup for your backups, or configure 2 independent backup schedules to run everyday.
  • Do not rely solely on a disk-to-disk backup solution. Although disk-to-disk backup solutions offer many advantages over traditional tape backups, they should not be the only backup solution to rely upon. In such a scenario, the backup server is prone to the same risks as the servers it protects. A hurricane, lightning strike, fire, or flood could wipe out your backup server along with your other servers. For this reason, it is important to dump the contents of your disk based backups to tape on a frequent basis, and then store those tapes in an off-site secure storage.
  • When deciding to replace your current backup technology with a newer one, do not get rid of the old tapes, tape device(s) & backup software. At least, do not do this unless you are sure that your newer tape device(s) support the older tapes, or that you have moved the older backups to newer media supported by the newer tape device(s). This way, when it is required to retrieve data from the old backups, you will be able easily to retrieve the required data. This also could apply to the older backup software if the newer backup application does not support the older tapes or tape device(s).
  • There is no denying that it is important to secure your backups, but it is equally important to consider the consequences of your security measures. If you find yourself having to restore a backup after a major system failure, the last thing you need is an ill-conceived security mechanism standing in the way of the recovery. For example, if you are planning to use hardware-level encryption, do not forget (when time comes to upgrade your backup hardware) to make sure that your new hardware supports the previously used encryption.
  • Always use a long tape rotation scheme, or at least keeping some of your backup tapes as long-term archives.
on Jan 05, 2010 | Computers & Internet
Tip
Backup Best Practices
on Jan 04, 2010 | Computers & Internet
Windows not loading
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 05, 2010 | Computers & Internet
Reboot my Acer Notebook
Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Keyboard command not working
The file that contains your keyboard short-cuts is acad.PGP. Find our where this file isand then use the OPTIONS command to make sure your PGP file location is listed correctly.
Tip: you can open this file with notepad. You will see how it is organized and following the same pattern you can add your own short-cuts and/or change the ones you already have.
Nov 12, 2007 | Computer Associates BrightStor ARCserve...
Computer Associates BrightStor ARCserve Backup Release 11 for Windows Agent for Backup Agent for MS Exchange Premium Add-On for PC Logo
1,318 people viewed this question
Top Computer Associates Computers & Internet Experts
Alun Cox
k24674
Are you a Computer Associates Computer and Internet Expert? Answer questions, earn points and help others
