Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Old flash i have an old sunpak softlite 1600a flash. will it damage my digital rebel xti?
    Problem Solver:
  • 5 Answers
What about my speedlite 200e?
Posted on Jan 06, 2008
    Problem Solver:
  • 24 Answers
At a whopping 46.6V.. yes, it would damage it.
Posted on Dec 06, 2007
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
How can i hook my sunpak 544 to my rebel xti without a slave unit reacting from my internal flash?i see no sync plugs to use on the unit. do they make an adapter or something?
All photo shops hold "hotshoe to PC" adapters for a few bucks. This solves your problem, supposed you have the hosehold-to-PC cable that comes with the 544 as accessory. If not, such cable can be obtained at better photo shops or from www.paramountcords.com. You must know that the flash can be used together with your camera only in Aperture Priority or Manual mode (flash set to auto), or as a fill flash (flash set to Power Ratio mode). The 544 has safe sync voltage.
Oct 12, 2009 | Sunpak Auto 544 Flash
Can i use my sunpak 4000af with my canon rebel t1i?
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Sep 30, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Can I use sunpak 1600a flash (older) with Pentax k10d dslr ?
Yes, it's possible.
The flash sensor is calibrated for a 35mm optics & iso (asa).
You may have to "UP" your digital camera's iso sensitivity to 800 or so.
You will have to experiment with it at various settings.
Try using the "bracket" sewtting on the camera.
It takes three pictures when you press the shutter button; the three have different "values" of brightness.
The bracket setting is on the UP arrow, where you can choose "single frame", "continuous frame", bracket, etc.
Hope this helps!
Sep 14, 2009 | Sunpak Cameras
Need manual for Sunpak 4000AF Power Zoom Flash
Regarding using the Sunpak 4000AF flash with my Canon EOS Digital Rebel, I can't get the flash to fire. There seems to be no combinations of settings that works to make the flash work. Could a weak battery in the Canon cause this? Does it require some other wire connector between the flash and the camera?
I know this is old technology now, I have a pocket digital for most of my uses, but I'd like to try bounce flash again on my old Rebel digital, and so I've gotten out my old camera and the flash I had bought for it. I had bought the Sunpak flash years ago and I honestly don't remember if I got it to work back then or not.
Thanks for any advice.
Jun 25, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Canon I use the Canon XTi and sunpak 544
The Rebel XTi has a sophisticated communication protocol between the camera and a dedicated flash. Only ETTL-II capable flashes can benefit from all the features the engineers at Canon thougt out. This means that with the otherwise superb Sunpak you won't be able to emit autofocus assist pulses, red-eye reduction pulses, the camera won't increase or reduce the flash intensity for bracketing, zoom lens settings won't be reflecting on the flash illumination angle, and so on. But! Set your Canon to full manual (125th sec), set Sunpak to auto, take one of the working apertures according to your taste (depth of field, etc.) and set the same aperture on the camera, and shoot. You still can use bounce flash. I am not sure about second curtain flash, I suspect it won't be possible. Both tele kit and milky filter in front of the flash head are of great help, you don't need to worry about the differences these make in flash intensity. Always keep in mind that the flash makes good exposure according to the given working aperture and, as long as you set the same aperture on the camera, the subject will be correctly illuminated. (I have a Sunpak 522 and a 455 and employ them this way, with success, on my XSi.) Of course you can set set the flash in full manual (M/PR/MD), using the left side, set knob and calculator dial, and this is the only way if you want to make series of shots, because the flash can only make bursts if the power is reduced to at least 1/16th. Good light, Laszlo
Dec 06, 2008 | Sunpak Auto 544 Flash
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Sunpak 2000 DZ
see if this helps:
http://www.flickr.com/groups/400d/discuss/72157603805472662/
Feb 10, 2008 | Sunpak 2000DZ Flash
Sunpak softlite 1600A for fz20
According to this site, the Sunpak 1600A is NOT USABLE with the FZ20: http://www.botzilla.com/photo/strobeVolts.html The tested voltage of the 1600A is 46.6V, which is WAY above the 24V max specified by Panasonic. Don't even try it...
Sep 06, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
