Question about Maytag CWE5800A Electric Double Oven
Have Maytag CWE550 looks alot like CWE5800 need to hook up power.
Built a new home after Rita, and bought a used Maytag CWE550 and cannot figure out where to hook up the 240Volt power cable. Please help.
2 Suggested Answers
SOURCE: we bought a maytag electric over built in type,
Open the door and look inside near the base of the door. It will say the voltage. Ours is 110. You can go to the maytag website to get an owners manual and installation manual for free.
Posted on Jan 07, 2010
I need new door seals. Where do I get them in Australia?
YOU MAY HAVE TO PULL OUT YOUR OVEN FROM THE WALL COMPLETLY TO LOOK ON THE BACK TO FIND MODLE NUMBER IT USUAL IS SMALL AND AT THE VERY BOTTOM OF THE UNIT. IF IT BUILT IN THEN LOOK UP ON LINE TYPE IN BENDIGO OVENS AND MAYBE YOU CAN FIND A MODLE NUMBER OR GO BACK TO WHERE YOU BOUGHT IT SO THEY MAY BE ABLE TO LOOK IT UP TO GIVE YOU A MODLE NUMBER. YOU MAY ALSO TRY LOOKING AT LOWE'S ON LINE AND MAYBE FIND ONE THEY CAN SHIP TO YOU OR HOME DEPO MAY ALSO HAVE ONE THEY CAN SHIP TO YOU IF YOU DO NOT HAVE ONE OF THOSE STORES WHERE YOU LIVE.
Jan 27, 2015 | Ovens
How do I replace the bottom oven element on my Maytag CWE5800?
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Feb 08, 2014 | Maytag Ovens
Gas oven repair for Maytag Oven CWG3100AAE after a
More than like a surge has fried most of the electricals in your oven. Since you are dealing with a gas appliance I suggest be very careful. Even the tiniest gas leak could result in your residence blowing up, etc.
For this reason I recommend call your gas company, and have them come out and install a new one for you.
It's just not worth the risk.
Nov 19, 2017 | Maytag Ovens
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
Which plug you use depends more on the outlet in your house than the oven usually. If This is a new oven with digital controls, 4 is preferable (I've seen a digital dryer blow the boards because a 3-wire lost it's ground) but if the outlet is 3, you don't have much choice but to go with 3 unless you rewire the outlet back to the fuse/breaker box. As long as it's in good condition, 3 should work fine.
Feb 14, 2011 | Maytag Ovens
Maytag oven, top door has lost the middle open position, falls freely and does not close well on its own. Model cwe5800ace. How do I access to inspect and/or repair?
Here is the body parts diagram of the Maytag CWE5800.So this will help you out in more depth.Please the link to so you can see other parts how it is linked to door too.
Click here to get to the body parts diagram.how to assemble it.
Hope this will help you,
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | Maytag CWE5800A Electric Double Oven
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Fried a new oven
black is 110.v red is 110 v =220 volts white to center terminal . bare to frame of oven .. the damage could be to the pc board and the eoc ( clock) any fans ect . it may be more than you want to spend .. panel is 155.00 the clock is 155.00 fan 70.00 . you may not need all of this ., oven cost 764.00 / repair it .. mm /
Dec 03, 2009 | Maytag MEW5527D Electric Single Oven
We bought a maytag electric over built in type, and not to sure if it is a 110 or 220 amps / volts also need information to hook it in
Nov 27, 2009 | Maytag 24" Built-In Single Electric Wall...
I want the oven to start when I am not there, how does it work
you probly have a time bake feature built into the oven each one diff consult the manual, if your oven has it itll be listed there
Feb 23, 2008 | Maytag CWE4800A Electric Single Oven
F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Dec 21, 2007 | Ovens
Maytag CWE5800A Electric Double Oven Logo
231 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
