Question about Sony VAIO VGN-FJ270/B Notebook
Battery Issue Yesterday I was using my laptop on battery power, and I closed it, putting it into hibernate. When I took it out of my backpack (less than a minute later), it hadn't fully turned off. I opened it up, and the hibernation screen was up, but very faint. Nothing was happening, so I had to just turn it off. When I opened it again, the battery had completely drained, and I put it back in hibernate to reserve the power. Then I noticed that my power LED was blinking... But it was red. It looks like it's a problem with the battery, but would anyone be able to confirm that for me? Also, is there something I can do to fix the problem or is my only option replacing the battery? It's not a huge problem as I usually have it plugged in anyway, but I can see it being a problem at some point. Thanks for your help.
  • Lindsay74 Nov 27, 2007
    Thank you, but I think I may have figured out the problem... It had to do with another setting I was unaware of.
    The battery still isn't keeping it's charge very well, but I'll definitely check into what you suggested to see what I can do about that. Thanks again!
  • 31 Answers
You can try looking up in the user manual what the red blinking light means. If you do not have a manual try downloading from the manufacturer's site.
If the laptop is usually plugged it then it could be that the battery does not charge properly. Try to recalibrate the battery. There maybe an option to do this in the control panel or in the BIOS Utility. If not, check the manufacturer's site for a utility.
To test the battery plug it in long enough to charge it then unplug and see if the laptop stays on.
Hope this helps!
Posted on Nov 27, 2007
Not waking from sleep
Don't be lazy, use the Shut Down command and then you will know your files have been closed properly and disconnecting the battery or power failure will not kill your data.
Apr 01, 2014 | Computers & Internet
My Asus K55A-DH71 laptop, was fully charged less than 24 hours ago; it hasn't been used or on since, and when i powered it up, it only had 6% power.
Fully charge it and take the battery out and let it sit for 24 hours and then put the battery back and power it on. Sounds like the battery is losing its life.
Dec 02, 2013 | Asus Systems Asus K55A-DH71 Core i7-3630QM...
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Lenovo Think Pad T61P dead.
Did you try removing the battery pack and then putting it back in? I had disconnected my AC, closed the lid, put it in my backpack and went to the office. The battery light was on when I left but by the time I got to the office it was DOA. After checking the AC at the office I took out the battery pack and put it back in. Voila.
Jan 27, 2010 | Lenovo ThinkPad T61 Notebook
I have a Thinkpad t60. For the past few days it won't go into hiberation when I close the lid. It just stays on and consumes the battery.
I have seen this issue before with my T60. It seemed to be related to not having restarted my laptop in a while. I used to use hibernate rather than shutting down my laptop for weeks at a time. Actually restarting my laptop seemed to get hibernate to work again.
In addition, you can check to see if for some reason the hibernate option has been disabled.
In Win XP (Win 7 is very similar):
  1. Click Start and select Control Panel.
  2. Double-click Power Options.
  3. On the Hibernate Tab, ensure Enable hibernation is selected (check mark).
  4. On the Advanced Tab, ensure that the setting for When I close the Lid is set to Hibernate (select it from the drop-down list if necessary). There should be an option for when plugged in and when on battery. Set both to your preference.
Hope this helps. Thanks for using FixYa.com
Jan 18, 2010 | Lenovo Thinkpad T60 Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Laptop Doesn't Turn On At All
To take out of hibernation,press the power button for less than 1 second.
Then go into the control panel and disable hibernation as described below.
Disable the your mouse's "ability to wake up computer" in device manager.
Use keyboard to wake up your computer.
Click Start > Control Panel > Performance and Maintenance > Power Options > Hibernate tab.
Then clear the Enable Hibernation check box.
If this doesn't resolve the issue,Please post back.
Please rate this a fixya.
May 17, 2009 | Compaq Presario M2000 Notebook
Dell 8600 Won't Power On
Try taking out the memory and put it back it. I probablly needs to be reset
If you need further help, reach me via phone at https://www.6ya.com/expert/marlo_032032486ea0d83f
Dec 10, 2008 | Dell Inspiron 8600 Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
