Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 pc screen problem
Help my lcd screen just went very dark - I rebooted and waited for a couple hours and still it comes up dark - I tried increasing the brightness using the function combination keys but yet still it is dark.
Help!
-Girendra
  • Girendra Nov 27, 2007
    No I havn't. But even the the screens before windows xp loads are dark. Th bios info screen is also dark.
    -Girendra.
  • SITH Dec 01, 2007
    Yeah same here ! It just suddenly went dark. I still can use my laptop but the screen is just crappy. And NO the problem is not with the drivers. It is like this when only the bios loads in as well.
  • 156 Answers
When the following symptoms, you need to replace the Acer LCD screen
No image on the screen, but the power indicator stays in
Dark display but still readable
1/2 to several seconds between the screen flashes on and off
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Image cycle on and off, as well as high power LED light
Posted on Apr 29, 2013
  • 57 Answers
Have u tried re-installing the video drivers?
Posted on Nov 27, 2007
I have an acer aspire 5630 it has worked well for nearly 4 years, about 4 months back I noticed that the screen would be dark and slightly reddish for the first 30 seconds to a minute after turning it on...
hi
try rebooting the system (i think its F8, to get to SAFEMODE) . in DESKTOP , right click and go to PROPERTIES, go to SETTINGS, go SCREEN RESOLUTION and take the arrow to the left ; set to 640x800 and and take the color setting to 256 drop down . hopefully this works after rebooting the system. if it doesnt, it may sound like the inverter card may be bad (PC bourd that connectes to the screen : this requires a service technician)
good luck !
Dec 09, 2011 | Acer Aspire 5630 Notebook
Acer aspire 3610 graphic or battery problem?
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Sep 01, 2007 | Acer Aspire 3610 Notebook
My screen keeps going dark. I have replaced the
Its not the inverter, it's your backlight. Hard work to change, sorry, and it might be cheaper/quicker to replace the whole lcd panel at $100 (£65)
Jul 26, 2010 | Acer Aspire 5610-2328 Notebook
How can i find out part numbers for acer aspire 3000/3610. I have a 3000 (broken screen) and a 3610 (dead) , can i swop the screen from my 3610 into my 3000?
The Acer 3000 series and 3610 series has different set of Parts, Hence Swapping the LCD screen may damage your other 3610 LCD also. Please try to get a replacement for Aspire 3000 LCD.
Thank you for using Fixya.
Oct 08, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Screen has just gone very dark acer aspire 5351
If you look very closely, can you still see things on the screen? Try moving your mouse around or clicking on the Start Menu in the corner. If you can see images on the screen but there's no light coming out of the LCD, then the backlight in your LCD panel just went out. It happens sometimes, and there's not a quick fix for it. You'll have to send it off for repair or get a replacement LCD screen. If there appears to be light coming out of the screen, but it's just not bright, you may be able to adjust the brightness using the function keys on your keyboard.
May 13, 2009 | Acer Aspire 5315 Notebook
The screen won't light up on acer aspire 3000
This could be a few things. More than likely it is your LCD Inverter or LCD backlight went out. If you look very closey in a bright lighted area, can you see words? If so it's your backlight. If you cannot it's your LCD Inverter as long as the screen isn't broke or no cables have been damaged.
Either one of these are going to require someone with experience to replace them. However, knowing the problem before hand will save you an hour worth of diagnosting fees and will give you the ability to get a quote over the phone.
Please let me know if this points you in the right direction.
Thanks,
Adam
Nov 22, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3000 display problem
i think its ur video card that has a problem.. try bringing ur laptop to the company of yuor laptop 2 fixed your problem.. hope it can help
Nov 07, 2007 | Acer Aspire 3000 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
My Acer Aspire 3000 is really dark and dim
If the brightness is dull even when connected to the mains, it maybe that your back lighting is faulty on the screen and you will need a qualified repairer, although it may be worth looking at a new notebook depending on the cost.
Feb 14, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
630 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
