Question about Kenmore 73952 Gas Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
I've had this KENMORE GAS DRYER 110.73952 for about 4 years. Everything seems fine.. except sometimes it just won't heat... the gas does not ignight. The gas valve is open and i have not tripped a breaker/fuse... the setting are on HEAT.
This same exact issue happened a few months ago... after a couple weeks I was getting ready to call for repair... when just on a whim I turned it on.. and what do you know.... it worked fine.. heat with no problem. What is up with this dryer?? Any help is appreciated.
  • 1 more comment
  • Anonymous Dec 10, 2007
    runs but no heat
  • Indy black Feb 07, 2008
    I have the exact same problem, Kenmore gas dryer about 4 years old and all of a sudden....no heat!!
  • Anonymous Apr 11, 2008
    wont heat
Clean your dryer exhaust pipe
Posted on Mar 25, 2008
My dryer was 5 years old when this happened. It turned out there is a fuse in the dryer that needed replacing.
Posted on Mar 23, 2008
    Champion:
  • 210 Answers
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
I have a kenmore elite, model# 11062952100. Everything works fine but there is no heat on any cycle. it is about 5 years old. Whats wrong, cost to fix, is it worth fixing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Kenmore Dryers
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
Kenmore gas dryer,model 110 97220100 stock 72201 seems to function fine but does not heat I have contenuity across part no. 43
heatman101
Dec 16, 2010 | Kenmore Dryers
My kenmore elite electric dryer inconsistantly starts to heat and
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
The dryer works, heats, tumbles, everything is fine. Except that there is a thump as the drum turns that seems to be coming from the top.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jun 17, 2010 | Kenmore 93042 Gas Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
My drier does not heat at all , everything seems fine except it does not ignite.please help
Hi, thanks for the inquiry.
If it's a gas dryer, it's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
Either way, it should only cost you about $90 to repair if it's a gas, and between $100 and $120 if it's an electric.
Best of luck :)
Sep 14, 2009 | Kenmore Dryers
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore 73952 Gas Dryer Logo
221 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
