Question about Symbol LS 4278 Barcode Scanner
Red Beam stuck on
The red beam is stuck on. The trigger seems to be just fine and doesn't appear to be stuck. The beam stays on whether the gun is mounted to the base or not. We can't scan anything or try to reprogram because the beam does not respond with any bar codes. I've never ran into this problem with any of our Symbol guns. Any Ideas? Thanks!
  • 25 Answers
You sound like a pretty experienced user. You've likely already tried pulling the battery for an hour replacing the battery, and then defaulting.
If you haven't try it. Symbol gear is excellent, but even BMW'a break occasionally. Our shop is one of many that can effect a hardware repair.
Posted on Jan 05, 2008
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
How do I turn on the beam on a motorola MC9090
There may be a fault in the circuit that turns on the beam or the trigger may be defective.
Feb 02, 2012 | Zebra Symbol Technologies MC909X-G Series...
I have serveral PDT6842 scanners that initial have a dot beam, but changes to a full bar beam when the trigger is released. How do I change it back to a full beam with no dot?
it depends on the type of imager - sounds to me like you have the red dot/green dot scan engine. Its not possible to change it back
Nov 01, 2011 | Symbol PDT 6846 Portable Terminal
Electrical Problem
check ignition switch and wirring , may have a short. had similar problem on 84 ultra wirring at switch had shorted out on frame
Oct 09, 2008 | Harley Davidson Harley-Davidson Motorcycle...
No Hi Beam on 93 Camry
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
Sep 10, 2008 | 1993 Toyota Camry V6
Have some red shadowing in picture
Without seeing the set and checking it out, this is hard to accurately tell.
The following is when a single CRT or tube in a projection TV set starts to get weak. It is the same for a CRT when any one of its electron-guns starts to go weaker than the others.
On any CRT based set either with a single CRT or with seperate projection CRT's, as the tube(s) (CRT's) get weak their emission goes down. One of the symptoms is that the beam focus gets softer.
When a CRT goes weak the beam current will decrease. This lowers the mass or intensity of the electron beam. This makes the beam width wider, and thus the image focus is softer. Having a wider beam in a single CRT or single colour section of a CRT's electron gun also means that there will be more beam width overlap in comparison to the other CRT's or the other electron-guns in the case of a single CRT. This will give the appearance of an overlap or edging especialy with sharp or thin lines.
There is also a symptom where the convergence can get less accurate as the convergence control circuits age. This means that the scan tracking between each of the CRT's or the electron-guns in a single CRT start to not be able to accurately keep converged to each other. This will produce a border effect between the beam position accross the scanning of the screen.
Sometimes with a projection CRT set if there are separate focus controls in the high voltage (HV) section for each of the colours the beam focus may be able to be cheated if the CRT is not too weak. In most CRT sets the focus voltage is shared between all the colour channels, and thus there is no possiblity to control each channel individualy.
With weak CRT's there are other factors that come in to effect. One big one is that the colour tracking gets impossible to be accurate. This is because the gain liniarity of the tube becomes out of spec. As each of the CRT's or the electron-guns in a single tube become weak they will lose their tracking accuracy in relation to each other. In the design of the drive circuits of the better TV sets there are some auto circuits to try to make sure that the tracking is stable. But, when the electron-guns become too weak the circuits run out of range.
Jerry G.
Apr 14, 2008 | Televison & Video
Ir devices
Infra red light is present all about us. It is generated by most types pf artificial lighting, and also by the sun. If yo have an infra red beam that is misfiring, it probably relates to some reflected light from a fast moving source that is triggering your beam. Hope this helps, not really sure what a beak beam is... guessed it was a typo. Give me a bit more about your problem if i ahve not helped thus far
regards
Graeme
Mar 16, 2008 | Microsoft Windows XP Professional With...
Symbol LS 4278 Barcode Scanner Logo
407 people viewed this question
Top Symbol Computers & Internet Experts
 Brian
Brian
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
