Hi I have problem with my richo aficio mpc4502 with code SC672 help me pleas with that
SOURCE:
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
Posted on Oct 27, 2008
  • 19 Answers
SOURCE: Richo Aficio 450e photocopy machine (Error Code SC360)
Replace HDD
Posted on Dec 24, 2008
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try reset the software… press the point and numeral key simultaneously until automatically it is off the copier, several seconds can pass, the copier back on automatically. The software will have been loaded again.
If the problem persists it proves with another hard disk,
since the other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another problem that sometimes cause erratic errors in these copiers is that it has fallen develop in some sensor having caused short circuits that annul to some times some voltage of the power supply interrupting processes indispensable for software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can seem incredible but it is thus.
For it would recommend a deep cleaning of the sectors of the image unit and everything what is under the development unit.
Posted on Sep 02, 2009
joel_baleta
  • 155 Answers
SOURCE: What is meant by error code SC 403 of RICHO AFICIO
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Posted on Jan 24, 2010
santosj27
  • 263 Answers
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
Posted on May 11, 2011
How to reset error code SC-900 on Richo Aficio mp2500
Hi, Not sure if this will help with your particular copyier, but try this link, it's much easier than trying to explain it all in this format.
https://www.youtube.com/watch?v=7BWO5t_V2uY
Hope this helps
David
Dec 11, 2017 | Office Equipment & Supplies
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have Richo Aficio MP 1600 all in one device-- Faxes fine, copies fine; Cannot get scanner to connect although Twain drivers are installed & device is connected to the network with its own IP address,...
Make sure the gateway is entered correctly, are you scanning to file or E-mail? Using web immage monitor is the easiest way to do it either way. if you have questions e-mail them to quennie@wcvt.com -Carl
Jul 07, 2009 | Ricoh Aficio MP1600SPF Copier
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
23 people viewed this question
k24674
Marvin
Marvin
