Question about Electrolux Dishwashers
I have an electrolux eurpoean dishwasher. I fill the salt when light signals but it seems that recently it signals again very quickly after about a week or so, that didnt used to be the case...why?
SOURCE:
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
  • 641 Answers
SOURCE: dishwasher options
You should buy a dishwasher salt (don't put in cooking salt !!!!!) The dishwasher salt is a particular grade of crystalline sodium chloride intended for use in dishwashers.
Posted on Sep 16, 2007
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
Dishwasher salt light wont go out after filling it with salt and everything is coming out white
well,if you fill it with salt and the salt light wont go out,and your dishes came out white,PLEASE STAY AWAY FROM THE DISHWASHER! the salt light is a warning light ,not to fill it but to delime it! wow,
Apr 23, 2015 | Dishwashers
Salt is blocked and not going down
u take dishwasher pump apart and cleaned from salt using water, it seems that the pump was jammed .
Oct 19, 2014 | Bosch Dishwashers
Hi, my wife refilled the salt, then the machine starts but won`t fill or cycle through. We`ve removed any excess salt; still nothing. Any ideas?
The watter inlet is cloght with salt,flip the machine side ways and shake it a bit the salt cristals should move from the water inlet
Oct 19, 2013 | Electrolux 23 in. ESL6114 Built-in...
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Salt light stays on
There is probubally an sensor in the machine that senses salt levels, it is not uncommon for and sensor to be faulty out of the box, I would contact the manufacturers on their 1-800 number nd consult with them and if be order the replacement part from them directly. Hope this helps
Sep 08, 2012 | Amana Dishwashers
Low salt light
try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Jun 24, 2008 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher
Hi there.
Check salt and rinse-aid levels first. Often there is an indicator if either of these falls below a level.
When was the last time you filled them?
Top up rinse aid to mark, and add at least 1kg of salt.
Run M/c on a quick cycle and see if it's back to normal.
Hope this helps you.
Jun 14, 2008 | Dishwashers
Salt in the dishwasher
Run a full wash without any salt in it and then try I think you may have over filled the salt tank.
Thanks J
Jan 13, 2008 | Beko 24 in. D3421F Free-standing...
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
