Question about Canon Office Equipment & Supplies
Canon p 150 start button grayed out - Canon Office Equipment & Supplies
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Hoping someone can help me fix an issue with a Canon DR-150 (also P-150) document scanner. Driver & software are installed, but the START button is inactive in that so-called CaptureOnTouch software....
First make sure scanner is recognized in computer for that make sure in device manager there is not any ? mark or yellow ! mark. Uninstall all usb drivers from device manager also from control panel->add remove programs uninstall scanner software then reinstall then you can use it again. Click here Click on above link and select os and download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
May 27, 2011 | Canon Office Equipment & Supplies
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
May 03, 2011 | Canon Office Equipment & Supplies
Torn gray and brown colored plastic came out of the printer and gives dirty print-outs
The gray/brown colored plastic is actually the teflon sleeve from the fuser unit in the printer. The fuser is the part that heats up and melts the toner onto the paper. Your fuser sleeve has torn and is being ripped every time you try to print and pieces are coming out causing the bad print. You will need to replace the fuser, the part number is FG6-7947-150 you can order one from several places on the internet.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Canon imageCLASS D760 All-In-One Laser...
Erase All button is grayed out on my Canon Powershot SD550
Okay. You can try resetting the unit to factory default. But I just want to warn you that this will delete all settings on your camera.
To RESET it to factory defaults, all you have to do is go to the Tools menu. This is the hammer and wrench tool I guess. And then hit Reset All.
Aug 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
How to start scan from canon pixma 150
Hit the SCAN button second from the left on the scanner; if you installed the driver (updated, etc.) correctly it will scan into a program set in its preferences using its TWAIN driver.  If you want different behavior than you can get from the TWAIN driver, get in there with your favorite programming environment and make the button do what you hope....
Jul 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Will not stay running.No power to the fuel system,tank pumps dead,booster pump dead and can't switch tanks.Fuse ok in dash,both relays are working...(help) I hade to hard wire my booster pump just to make...
Take the drivers side kick panel off there is a fuel safty cut off it is a gray box with a button on top push the button in see if it starts if not check the plug in the box to see if it is burnt my ford f 150 is a 87 and thats what happened to it hope this helps
Mar 10, 2009 | 1987 Ford F 150
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon zr200 Gray lines
Change your resolution and it should go away.
Dec 17, 2007 | Canon ZR200 Mini DV Digital Camcorder
Open Questions:
21 people viewed this question
Clive
Clive
old marine
old marine
