Question about Mitsubishi Televison & Video
I have a 65" mitsubishi model wd-65733 with sound but no picture
    Dedicated:
    Visited the website for 20 consecutive days.
  • Mitsubishi Master
  • 478 Answers
Dear SHEILA,
It looks like you have a Lamp problem and/or DLP Chip gone bad. If you are handy enough, you could troubleshoot and repair the TV. If not take it to a TV repair shop, It may be costly or just simply get yourself a new TV.
Below find some links to help with the repair.
Be sure also to take all the precautionary measures to insure your safety, should you decide to do it yourself. Let us know how it turn out and you should need further assistance.
Best of luck! https://youtu.be/5vBUWKX96Y0
Posted on Jun 16, 2019
    New Friend:
  • 38 Answers
The bulb is out. You can purchase on amazon for around $20.00. It is a very simple fix. Should take about 5-10 minutes
I have a 65
SOURCE:
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
ladywinn
  • 5138 Answers
SOURCE: I just replaced the blub on a Mitsubishi 65 inch
Ballast Board 1-800-638-3328
Posted on Oct 21, 2010
ladywinn
  • 5138 Answers
SOURCE: My mitsubishi wd-65733 is making
Lamp could be the problem or Ballast board that powers Lamp on. Encompass Parts Distribution visit their website and look up your Model#
If Problem is Lamp Mats has them for $99.00
1-800-628-1118
Posted on Oct 23, 2010
  • 441 Answers
SOURCE: How do I remove the screen protector from a
That is a full tear down! I would be very careful when doing this and be in a very clean dust free area!!! You will need to lay the set face down and remove all of the screws around the edge of the set. You will see that the back panel is in two parts you will have to remove them both. Once you have the rear plastic cover off you turn the set over and will be able to pull the screen up and off.
You run the risk real damage to the set with a job like this, the only reason anyone should ever do this is to replace the screen. If you are trying to clean the mirror inside use the small circular doors 3/4 of the way up the back of the set on the sides.
Posted on Nov 27, 2010
  • 1156 Answers
SOURCE: getting white spots on my
Hi,all HDTV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board and also white spots.
A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Good luck.
Posted on Jul 18, 2011
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Trouble shooting wd-65733
Mitsubishi's troubleshooting page:
http://support.mitsubishi-tv.com
Click on the "GO TO TROUBLESHOOTING >>" link.
Here are Mitsubishi's (3) downloadable PDFs for the WD-65733:
http://support.mitsubishi-tv.com/documents/WD-65733
Dec 21, 2011 | Mitsubishi WD-65733 65" HDTV
My mitsubishi wd-65733 is making a strange clicking sound from behind the tv and there is no picture. then the sound goes away after like twenty seconds then will do it again pretty quick after.Any...
1-800-628-1118
Oct 23, 2010 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Blessings,
A/V Media Guy
Nov 20, 2009 | Mitsubishi WD-65733 65" HDTV
Crackling noise on wd-65733.Timer light flashes.
put back your board its a cold solder from CRT socket board and the main board. if not check your tuner.
May 06, 2009 | Mitsubishi WD-65733 65" HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
