It means when you mention a tweet instead of posting a screenshot of tweet you grab a small copy of code from Twitter and paste it on your blog. This will make that tweet appear in your blog post. The benefit is that you will get real time stats, when it was posted, how many retweets it got. https://www.google.com/search?source=hp&ei=NtAFXY2HL-nM5gLq3rPgAw&q=what+does+embed+tweet+mean+on+twitter&oq=What+does+Embed+Tweet+mean+on+Twitter+%3F&gs_l=psy-ab.1.0.0i22i30.3333.3333..8585...0.0..0.398.594.0j1j0j1......0....2j1..gws-wiz.....0.mHxH_JIlIX4
SOURCE: direct messages being sent to twitter stream
When sending a direct message to someone, better do it this way -
d username <the message>
A couple of times it had happened to me that sending the dm to someone went as a reply to them openly in the timeline. So the option of sending it as said above is the best.
SOURCE: how do you tweet on twitter
Simply log in using your twitter user id and password, if you don't have one, create one here http://twitter.com/. Then click "Home" and type in the box under the words "What are you doing," then click "Update." There you go!
Hope this helps!
SOURCE: how do I tweet a question to a person on twitter?
SOURCE: HOW DO I REPLY TO A TWEET IN TWITTER
Hit the reply button under the trash can next to the specific tweet that you want to respond to and Twitter will automatically populate the text field with the user's screenname so you can reply.
Hope this helps, happy tweeting
SOURCE: Twitter problems since I got Lion
Have you run Software Update since you upgraded to Lion? You may have an outdated version of Java or Flash Player, or your browser may have a compatibility problem (if you are using a browser other than Safari, check the Tools or Help menu for a manual Update option. Some browsers have an Update button in the About... dialog)
