Question about GE Spacemaker JVM1640SJ Microwave Oven
Replace Blub GE Microwave oven Model 1540
Where do you access the bulb, there is a plastic cover top wall insideb but I can't seem to get it off
  • 4 Answers
On my Spacemaker, access for bulb replacement is on the top of the chassis, which is under the top/side cover. From a diagram I looked at, it appears that yours is similar. If so, you have to:
1. UNPLUG the microwave and then remove the three retaining screws that you'll find on shelf or cabinet above the microwave. Get help; the front of the microwave will be heavy when the screws come loose from the top.
2. Rotate the front of the microwave down a little and lift the rear up about a half-inch. At this point, it is free from the rear mounting plate. Set the microwave on a suitable work surface.
3. Remove the top/side cover piece. To do this, remove all the small screws on the top, the back, and the bottom edges on each side. Then slide cover back about an inch and lift it off.
4. In the middle section of the top of the chassis, you'll then see a cover above the location of the bulb. Lift it up to get access to the bulb.
It's a lame design for an over-the-range unit, but that's the way it is.
Here's a link to a diagram of what it looks like after you get the cover off: http://www.partselect.com/MultiModels.aspx?ModelNum=jvm1640sj&searchTerm=img_00115013i05&RefineSearch=0&imgMfg=GE
Posted on Nov 28, 2007
Replace inside light bulb
gonna needa open it up theres about 6 screws holding the covere and it like a small light blub u can uncrew it or if not it has a has a clip u pull off and are able to change it
Oct 13, 2014 | GE Spacemaker JVM1750 Microwave Oven
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
Does anyone know how to replace the light inside the oven? not the light that shines down. The oven does not light when you use it. The GE manual does not seem to have any information on this or any of...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If there's no obvious removable cover over the bulb and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (and 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jul 09, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
The interior light on my microwave convection oven doesn't light.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 20, 2008 | GE JVM1490 Convection/Microwave Oven
How do you replace the interior bulb in a Model JVM3670BF08
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
hope this helps dont forget to rate this
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Oct 19, 2008 | GE JVM1790 1000 Watts Convection /...
Replacing interior light bulb for ge spacemaker xl1800
Sep 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
Sep 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light bulb located?
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Jun 23, 2008 | GE JES1288SH Convection/Microwave Oven
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
144 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
