Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
Hi, my Whirlpool LTE5243D stacked dryer has not been working properly--it heats sometimes but not others.  I've tried running different cycles (including the timed high heat cycle which does not sense moisture), cleaned the lint, and checked to see if everything was attached properly.  Unfortunately, I don't have much other experience with dryers.  Has anyone experienced this problem or have an idea/solution?
Thanks
    Genius:
  • 1,224 Answers
Couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Posted on May 29, 2008
Dryer runs but the heating element is not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 02, 2011 | Whirlpool LTE5243D Top Load Stacked...
The dryer is not heating.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LTE5243D Top Load Stacked...
My dryer stopped heating. How can I trobbleshoot?
heatman101
Dec 13, 2010 | Whirlpool LTE5243D Top Load Stacked...
No heat in dryer
heatman101
Sep 22, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dryer heat doesn't come on
heatman101
Sep 12, 2010 | Whirlpool LTE5243D Top Load Stacked...
DRYER IS NOT HEATING AFTER CLEANING VENT HOSE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tyty
Apr 08, 2010 | Whirlpool LTE5243D Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
How do i get to the components?
working on either since stacked the washer top should be off, if working on the dryer remove the top the top is held in place with 3 screws washer likewise
Nov 29, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
118 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
