Question about Whirlpool Refrigerators
Whirlpool over under refrigerator ice maker builds up like a frozen water fall in the bottom of ice bin at the front of the ice maker unit?
SOURCE:
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: i have a Whirlpool refrigerator
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Posted on Feb 14, 2009
tborn6
  • 700 Answers
SOURCE: WE have replaced our ice maker in our Whirlpool
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Posted on Apr 04, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Sub zero 532, ice maker issue. water enter the cube bin freeze into a block of ice with the cubes embedded. What is the cause of this issue?
There is a few things that you will need to check to isolate the problem. this first thing is locate the fill tube where the water comes into the ice maker. What you are looking for is any ice frozen inside causeing an overspray of sorts. If that checks good, then the next thing is look at the icemaker itself. Look at where the water goes to and freezes. Is it completely full of frozen water? if so then the water valve is sending too much water either because the ice maker called for it or the valve stuck and didn't close when it was supposed to. If its not full, look at the bottom of the ice maker, checking if there are any cracks allowing water to fall into the bin. My personal opinion though would be to change the ice maker and the water valve because of the age of the machine. the bad part is the actual icemaker for that model has been discontinued but I believe you can use a whirlpool style that matches, comes in a kit that has both the water valve and icemaker, and cost almost half the price as the original. that part number is 1129313
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 21, 2012 | Refrigerators
New french door 27 cu ft....good performance for first two weeks...alarmed today by rapid dripping (for about 20 minutes) and puddle on floor in front of left front foot of unit. ...dripping stopped more...
The control board has a problem, we had the same problem and had the ice maker and control board replaced but we are starting to get ice building up under the ice bin. I'm very disappointed with this Whirlpool poduct.
May 10, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I replace the ice maker for my refrigerator{whhirlpool gold} but the new one do not fill the ice bin after more 24 hrs .is that normal?
The trick is to let the ice build up , close to the bottom of the icemaker . This helps cool the ice maker mold , helping keep up , due to ice usage . Also , make sure the coils under the front of the refrig are clean , this is very important . But , yes , the ice bin may only be 1/4 - 1/2 full , in 24 hours .
Sep 24, 2009 | Whirlpool Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker not working
GEARS UNDER FRONT PANEL OF ICEMAKER ARE WORN OR BROKE,YOU NEED NEW ONE,THANKS-MIKE
May 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking onto floor
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
