Question about Marvel Refrigerators
My marvel compressor not running what should I do?
The freezer in my under-counter Marvel refrigerator doesn't freeze anything
Could be several issues here ,first check to see if compressor is running ,if not then check why could be as simple as a relay or just a bad compressor. Check to make sure all fan is running that is evaporator that's in the freezer and condenser that's next to compressor.
May 05, 2018 | Marvel Refrigerators
Compressor
What information due you seek on this Marvel unit, What technical information are you wanting for this unit. This unit runs off a pod for the temp controls and if set wrong, it will not run. So what information are you seeking. The compressor is a 120V and can be wired directly to run. Please on you need of information so I can help you.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 15, 2013 | Marvel 61AR Compact Refrigerator
Marvel 60AR7701 not cooling
I have an older model Marvel 6OAR7701 outdoor Frig....the compressor doesn't start. It may have gotten wet in that area. Any idea's
Apr 14, 2012 | Marvel Refrigerators
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
I have a air compressor (craftsman) it will run constantly and never put air in the tank. it is about 35 degrees outside. when it is warm it works. the water has been drained
First try some light weight oil in the cylinders and see if that will make it pump air. If it does then drain the oil from the compressor crankcase and replace 1/2 of it with the required oil. then fill to proper level with Marvel Mystery oil. Run compressor for 30 or 45 minutes. Then drain the oil and refill with the recommended oil for your compressor. If this fails to correct your problem then it could be that the rings need replacing on the piston. If the marvel mystery oil didn't solve it then you need to replace the reeds at the base of the head between head and cylinder assembly. micmor68@gmail.com Mike
Oct 29, 2009 | Air Tools & Compressors
Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
May 24, 2009 | Marvel (6CAR) Refrigerator
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Refrigerators Logo
Top Marvel Refrigerators Experts
Marvin
Marvin
JohnB
Level 1 Expert
ray gallant
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
