Question about Hardware & Accessories
How do I program a khan 120 volt outdoor timer
5 Suggested Answers
SOURCE:
  • 760 Answers
SOURCE: i need instructions to programe
You need to provide a manufacturer and model number.
Posted on Aug 03, 2010
  • 5353 Answers
SOURCE: malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 22, 2012
  • 5353 Answers
SOURCE: Is there a manual available for a IIIWood outdoor programable timer
Copy following link to identify timer and download possible manual:
Try the Woods 49565.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#1507
2) If timer does not show on link above, add comment and include photo or clear description of timer.
Posted on Dec 06, 2012
  • 5353 Answers
SOURCE: Digital and mechanical timers that are part of a low voltage outdoor light system. Plugged into 120 volts ac outside in a sheltered area. Both kinds of timers consistently fail in the ON position. A t
1) Install arc fault breaker to the circuit and remove grfci
http://waterheatertimer.org/images/How-to-wire-GFCI.html#arc-fault
2) Test outlet with circuit analyzer for correct polarity and grounding,
Make sure there is not dual gfci protection on same outlet.
Move wire to different same-size circuit breaker.
Run another line to the same location.
Posted on Feb 22, 2013
How do I wire GE# 15351 24hr mechanical timer switch for 110 volt outdoor landscape lights
15351 is 240 Volt timer... requires 240 Volt to run clock motor.
You need a neutral wire to connect 120 Volt lights.
15351 has same wiring as Tork 1104
http://waterheatertimer.org/images/Tork-1104-wired-to-control-120.jpg
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
Gene
Sep 26, 2014 | Electrical Supplies
GE timer 15164 240v.
Copy following link to identify GE 15164 timer and download possible manual and see wiring for 240Volt application
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Sep 11, 2012 | UPM 120V/240V Heavy Duty Outdoor...
Malibu 8100-0300-01
Aug 21, 2012 | Hardware & Accessories
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
Tork 1104 is wired 120 vac. hot wire connected to L with jumper wire to 1.hot wire for outdoor lights connected to X. nuetral wires are wire nutted together. not connected to timer. clock not working....
The clock isn't working because the Tork 1104 clock motor requires 240 volts. Jumping the 120 volts over from terminal L to terminal 1 doesn't make it 240 volts. You need another 120 volt leg (180 degrees out of phase) to do that. The Tork 1103 timer is what you need, or change the 1104 clock motor to a 120 volt.
Dec 16, 2010 | Hardware & Accessories
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
The clock has stopped. I have to turn it manually. Its an outdoor timer with a cover.
If the clock dial does not rotate >> and the manual override works >> the the clock motor is bad.
The clock motor is replaceable. Snap out the insides, and the clock is attached with 2 small screws >>> sometimes these take a start screwdriver from the auto parts store.
On the inside cover of your timer is a sheet showing the clock voltage. Some clocks are 240 Volts, some are 120 Volts.
The back of the clock also has identifying numbers.
You say the timer is outdoor. A pool timer is probably 240Volt timer, with a 240Volt clock.
If the timer controls the sprinkler or lights, then the clock motor is probably 120V, with 120V clock motor
Grainger sells 120 and 240 clocks for the T100 series timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
A+ sells a long list of Intermatic clock motors
http://www.aplussupply.com/intermatic/timermotors.htm
If your timer is an Intermatic, you can also buy the whole timer, and then swap the insides without changing the box.
Oct 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic outdoor timer T8845Pv won't come on manually or auto
My first thought would be to make sure that there is power to the timer, 120 volts. Then I would check the wiring for the lights. then I would check the output of the timer with a voltage meter looking for the 24 volts.
Please vote !!
Apr 12, 2010 | Intermatic T8845PV - Sprinkler-Irrigation...
Hardware & Accessories Logo
37 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
