Question about Kodak Cameras
How can I turn the flash off on my Kodak easy share C433 camera
  • Kodak Master
  • 9,827 Answers
Page 7 of manual shows a button that repeatedly pushed will change the flash setting to off.
http://resources.kodak.com/support/pdf/en/manuals/urg00598/C433_GLB_en.pdf
Posted on Jun 14, 2019
SOURCE:
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
  • 30 Answers
SOURCE: how can i transfer pictures on my internal memory
u need the usb cable the camera came with
Posted on Jan 13, 2010
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
lock123
  • 6831 Answers
SOURCE: KODAK Easy Share V530 (Error # E45)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera turns on..sometimes turns off again...if lucky will take a picture before it turns off again.. the battery is flashing even though I have just changed them
My Kodak Easy Share C433 camera does the same thing! Does anyone have a solution?
"camera turns on..sometimes turns off again...if lucky will take a picture before it turns off again.. the battery is flashing even though I have just changed them"
Sep 22, 2011 | Kodak EasyShare C433 Digital Camera
My Kodak Easy Share C433 camera on the viewing screen only shows 1/2 of the screen. It has a Black triangle and then white on the left side.
It is not possible to buy a viewing screen for KODAK cameras.
If the camera has been dropped KODAK will determine this fault as Out of Warranty
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 20, 2010 | Kodak EasyShare C433 Digital Camera
My flash is not working
go to the menu and go to the settings/options and there should be a setting for plash or a button that has and arrow/lighting bolt figure and that should work.
Dec 27, 2008 | Kodak EasyShare C433 Digital Camera
Hi - You can download the software from the link below:
EasyShare C433
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 06, 2008 | Kodak EasyShare C433 Digital Camera
My kodak easy share c433
Are you using alkaline batteries? The Easy Share hates alkaline batteries. Try NiCad or Lithium.
Oct 16, 2007 | Kodak EasyShare C433 Digital Camera
Cameras Logo
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
