Keyboards and Mice
Problem for Keyboards and Mice
Generic problem for all Keyboards and Mice
Mouse not working..pls help
By sapphiregovu on Aug 08, 2009
the mouse works but only until i log-in the network user after that it stops working. The pointer is there but there is no motion or clicking. i tried to solve this by removing both com ports and the mouse prom the device manager and it works again but only until it re-installs the com ports. I should mention that on a previous atemt to solve the problem it tried to install some logitech mouse driver as the PC detected but the instalation failed and becouse of that the system would not start in normal mode(only in safe mode) untill i disabled the lmouse.drv from mscomfig. please help!
Clarification Request
Posted by cruelcode on Aug 08, 2009
Have you tried plugging the mouse into the keyboard port and if so did it work there
Solution #1
posted on Aug 08, 2009
Not Rated)
onlinetech
Rank: Wiz
Rating: 82%, 46 votes
i guess it is due to conflicting Com ports resources. you can try the following to resolve the problem. i am assuming you have a serial mouse connected to com port
1. remove any devices marked under device manager with yellow exclamation mark or question mark. reboot the system
2. when the system has restarted let the windows install any new devices it has found. after that.... go to device manager right click on com port to which mouse is connected
a) click on port settings tab and click restore defaults.
b) see if windows is reporting any resource conflicts under resources tab.
do you have any other device that is attached to any other com port ? if yes it may be causing resource conflict problems. to solve that click set configuration manually and deselect automatic settings and select different configuration in "settings based on" . this should resolve resource conflicts if any.
I hope this helps solve your problem
Was this helpful?
Yes
No
Popular Solutions for Keyboards and Mice
Questions and Unsolved Problems for Keyboards and Mice
Answer
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your... (More)
Answer
center wheel button will not zoom in or out . I use it for autocad. It used to but i recently... (More)
Answer
i have a logitech cordless mouse that is not working (i've changed batter and estill nothing). what... (More)
Answer
I am getting a message on my desktop "connection lost". Mouse not working.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Keyboards and... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
