Question about JVC Car Audio & Video
Jvc kds37 doing nothing only power getting to eject button. What can i do.
4 Suggested Answers
SOURCE:
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
  • 59 Answers
SOURCE: wired jvc stero in a
First check the fuses, if the fuses seem to be fine then do the following steps.
Try doing everything you explained with the ignition key in the off position. If you can still do all of that with the ignition off, then you probably have a bad connection on the RED wire. If you can't do that stuff with the ignition off, then you may have a bad connection on the YELLOW wire. Also you might as well check the BLACK wire (ground).
If the fuses were good and all of the wires had a good connection you may want to use a tester to check and make sure the wires don't have a short somewhere.
If you checked everything and you still have the same problem, then my guess would be that something has went out internally on the stereo.
Hope this helps.
Posted on Mar 14, 2011
kenw392
  • 2226 Answers
SOURCE: I've installed my JVC KD-S17
Do you have power going to the red wire?
Posted on Jun 06, 2011
I have a jvc am/fm cd player kds-30 it has no eject button anywhere and i can not figure out how to eject the cd
The eject button is just above the JVC logo on the display panel.
When you press eject and if it displays "NO EJECT", then it is locked. Press and hold CD and Power (ATT) for more than two seconds.
Feb 09, 2012 | JVC AM FM CD DET FACE CAR STEREO
My cd won't eject. the car recently had the altenator replaced and everything in the car was reset. could this have affected the cd player?
Some players get set to a default like when it was fresh out of the box when power is removed. Since you radio from the factory knows there is no disc in it, it thinks there is nothing to eject. Push the reset button and your disc should eject.
Jun 20, 2010 | JVC KD-S6060 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
6 discs in system, won't play or eject
take it manually by opening the unit
Jan 20, 2010 | JVC KD-G110 CD Player
My car radio jvc won't eject my cd? an need to kow how to?
this is a common problem with this model radio. if it wont eject by pushing the eject button. you can do a hard reset by holdin the SEL button & the POWER button at the same time until the until ejects your disk. OR pushing the SEL button first, then the POWER and holding both until it resets.
hope this helps
Sep 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
